Old 17-11-2007, 01:17 AM   #1 (permalink)
dOm1naTOr's Avatar
Default ndis.sis bsod problem
Whenever i start downloading any torrents contents via utorrent,azeures or flshget BSOD appears within 5~15 min and say there was a problem with da file ndis.sys.
I searched da net and found that its some problem with da torrents downloads got affected with some kinds virus/malware.
No i can't dl anythin via torrent....
what shud i do. Ihave scanned my pc with avg,avast,nod 32, zone alarm etc and all known viruses has been removed.
There is 100% no problem if i dun start any torrent clients.
I also restored the ndis.sys from XP cd to windows/system32/drivers, but the problem persist........................
PLZ guys......its urgent...plz help me
Also if i install comodo firewall, the net wud be cutoff after 1hr or so. But then also i can't use torrent in dat 1 hr.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 17-11-2007, 01:23 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: ndis.sis bsod problem
try to restore your system to best known configation.This may help you
ravi_9793 is offline
Old 17-11-2007, 01:41 AM   #3 (permalink)
dOm1naTOr's Avatar
even reinstall is not helping me
i can't format my entire HDD. I only formats c partition. Its takes a lot DVD s to backup my 250Gb HDD.
And if that bug arise again after i formated HDD and put dat discs again????
G3: XPS M1530 |
FZ 16.
Old 17-11-2007, 08:52 AM   #4 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
NDIS is Network Driver Interface Specification, More Specifically a Driver Controller for Network Drivers in Windows.
Are you by any chance using USB Port for connecting your Broadband? Do update all the Drivers.
Maybe the Driver is getting spooked when it encounters lots of connections and is crashing the System
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 17-11-2007, 09:49 AM   #5 (permalink)
dOm1naTOr's Avatar
I connect using RJ45.
I have two lan ports:
an nvidia gbit lan port which i use to gigabit lan with my 2nd PC.
And an 200 bucks 10/100 NIC. It has some silan chip. I use it for da net.
will try on nvidia lan port nd be back soon.
G3: XPS M1530 |
FZ 16.
Old 17-11-2007, 09:53 AM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
I dont think it is a LAN port issue.But anyway check this also.
PC down after BSOD satyamy Hardware Q&A 11 28-04-2007 12:20 AM
Bsod Alfansey06 Technology News 6 13-09-2006 12:24 AM
BSOD..help.. zuala77 Software Q&A 1 19-01-2006 02:16 AM
BSOD Problem ashu888ashu888 QnA (read only) 10 09-11-2005 12:48 PM
While initializing device NDIS: Windows protection error thind Software Q&A 1 27-01-2005 10:45 PM
