Old 15-11-2007, 07:11 PM   #1 (permalink)
Default INTEX TV tuner card
hi there I am going planning to buy a tv tuner card and the intex tuner card is within my budget range.I was just wondering if anyone of you have used this card and your experience with it.
which is the best tv tuner card in the market thesedays??
thanks
jambay19 is offline
Old 15-11-2007, 07:17 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: INTEX TV tuner card
pinnacle tv tuner card are good ..but are little costly.
ravi_9793 is offline
Old 15-11-2007, 09:58 PM   #3 (permalink)
Attitude matters
Ponmayilal's Avatar
Whether or not you are going to change over to Vista in the near future, go in for a Vista compatible TV tuner card so that you are ready to change over and use Vista Home premium mediacenter.Which Vista compatible tuner cards are right now available if someone can give a list and approx. price it will be helpful.
Ponmayilal is offline
Old 19-04-2008, 07:45 PM   #4 (permalink)
I bought intex tv tuner card but my even after connecting tv antenna and installing all the necessary drivers and software that came bundled with my intex usb 2.0 tv tuner card it does not show me any tv. The software itself is not able to detect tv. It only detect a usb tv camera and shows me svideo
You should first check the configuration of PC with which you are going to use.
The pack of this tv tuner card says it works with laptop with minimum processor speed 1770MHz.
And user's manual says it requires at lease pentium 2.7G
I think intex cheats its prospective consumers in this way .
Do insist a trial of the card with pc if you are going to buy this card
Please also help me if you find any way to run the tv with this card.
My pc is 1.86 ghz dual core pentium (acer 4710z series laptop)
sal765 is offline
Old 06-07-2008, 09:14 PM   #5 (permalink)
Same problem here..
Has anyone been able to use intex it160 TV tuner with VISTA?
Please respond.
Thanks in advance.
someone68 is offline
Old 08-07-2008, 12:20 PM   #6 (permalink)
Cool Buddy's Avatar
Buy a pinnacle card, they are good and not too expensive either. I just got one at Rs. 1800 +tax for one of my friends.
And don't expect picture quality like your TV.
Cool Buddy is offline
Old 08-07-2008, 08:28 PM   #7 (permalink)
Gizmo Freak !
spitfire's Avatar
There are some very good choices
1. TechCom SSD 670 : Amazing card...remote feels cheap...crappy software...but the picture quality is better than the pinnacle 50i I used to have ...Price abt Rs 800-850.
support vista
2.Pixelview Pro 3 : Very good card , FM , Good remote and very good picture quality. Recommended. Support vista as well . Price abt Rs 900
I've used almost 5-6 tv cards in my PC...so I have quite a bit of experience in this regards
spitfire is offline
Old 22-09-2008, 05:13 PM   #8 (permalink)
Well had you selected your country in the property settings . I guess that is your problem .
thundergamez is offline
Old 22-09-2008, 05:23 PM   #9 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
I had bought Intex internal TV tuner card with FM radio (model no: FM: 0412) @ Rs. 1200 last year. Its a total waste of money. Picture quality is not good even with digital signal!
I would not recommend this one. May be it happenned so with me because this was one of the entry level ones?
गीक होना माँगता
victor_rambo is offline
Old 15-12-2008, 03:05 PM   #10 (permalink)
Question Re: INTEX TV tuner card
i want a good tv tuner, that works with CRT & LCD and capable of recording video at high qlty. I used UMAX USB tv box (UTV330) whc. is gud in recording but all channels r not as clear as viewed in tv. (no prob. in cable). Also v cant resize tv wdw. it's like wdws media plyr, occupying 3/4th of screen.
Is tv tnr card difft. fr tv capture card? bcas i heard capture card records video at high qlty, but Tv tnr records in medium qly only.
tlsankar is offline
need help configuring my intex capture card !!! hmvrulz Reviews 5 22-09-2008 05:18 PM
Intex Tv tuner digitizen Hardware Q&A 5 22-04-2008 05:54 PM
Intex Internal TV Card patkim Hardware Q&A 1 10-06-2007 02:52 AM
Any one of u use Intex LAN card with linux ?? eagle_y2j Open Source 5 01-01-2007 09:46 PM
