Old 24-03-2005, 12:19 AM   #1 (permalink)
Default AVG7.0 offline Update
Can AVG7.0 be updated regularllythrough offline without connecting to the net?is there a way to install the updates which were downloaded somewhere else to my system?
jaideeprc is offline
Old 24-03-2005, 12:28 AM   #2 (permalink)
swatkat's Avatar
If you have the UPdate files with you, then you can update AVG.
Right Clikc the Control Center icon in the System Tray, and click "Check For Updates". It asks whether to get updates from "internet" or "folder".
You choose "Folder" and then show the path for the update file.
http://swatrant.blogspot.com/
swatkat is offline
Old 24-03-2005, 09:38 AM   #3 (permalink)
QA Juggler
saROMan's Avatar
OR the simple way.....download the Update File to your HDD ...then paste it in your AVG's Update folder...now when u fireup AVG it will detect it automatically and update
8-) सारोमान :!: :!: :!:
saROMan is offline
