Old 24-03-2005, 12:13 AM   #1 (permalink)
jay4u's Avatar
Default Where to create Pagefile partition....
I came to know that using a seprate partition for Pagefile speeds up the system. I have a 2.4 Ghz PIV with 512 Mb Ddr RAM, Samsung 120 GB primary and Seagate 80 GB secondary drive. Now where should i create my partition for keeping Pagefile in it. Also what should be the partition size and cluster size (default NTFS is 4k) that would be most effective.
Passwords are like underwear... Change them often...
jay4u is offline
Old 24-03-2005, 12:26 AM   #2 (permalink)
first best option would be on the drive other than ur OS
that is secondary drive
next option , on the furthest ntfs (in case of w2k/xp) partition ie last drive letter
next would be same partition as windows file
since u already have 512 , i dont think u need huge pagefile files . try to keep it short and spread over 2-3 partitions
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 24-03-2005, 12:35 AM   #3 (permalink)
Well to add to what klinux has suggested read this excellent article on virtual memory by alex nichol(MVP).
It should certainly enlighten you of the inner workings of virtual memory under windows xp.
www.Oobertech.net
digen is offline
Old 24-03-2005, 01:00 AM   #4 (permalink)
hafees's Avatar
The first partition will be the fastest one. so make a 1 GB partition with 64 k cluster size. 4 GB for Windows, 6 GB for Program Files, 4 GB (may be more ) for ur My Doucments.
hafees is offline
Old 24-03-2005, 01:17 AM   #5 (permalink)
you should cerate the page file partition on your secondary drive(also hope that you have connected to secondary ide of your system, it increases speed of disk operations) and it should not be bistributed but have a dedicated partiton to it
the partition should be ntfs with deafult cluster size and size = 1536 mb (3*ram, normally you should have 2.5 * ram but then you will be troubled many times with low diskspace error) then select the "let windows manage my pagefile size" on that drive and disable page file on all others drives
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 24-03-2005, 12:27 PM   #6 (permalink)
Ignorance is BLISS !!
Better u allow the OS to create a page file on a drive other than the Root partition !
rajkumar_personal is offline
