13-11-2007, 07:26 PM
Emergency!!!!
I tried loading a stupid webcam driver in my notebook...vista home premium...it has corrupted a file...ndisrd.sys I don't have the oS CD all I have is the recovery disk....but if i use the recovery disk, my hard disk will be formatted itseems....what do I do now?  (
I tht of making a boot disk and copy the file from somewhere....but it soesn't have a floppy drive...I have no idea how to make a boot disk in CD....plz plz plz....help
13-11-2007, 07:30 PM
Rubik's Uncle!!
Re: Emergency!!!!
pls give you laptop model.
try system restore.. last known good config
13-11-2007, 07:33 PM
Re: Emergency!!!!
HP dv6500t
13-11-2007, 07:48 PM
Rubik's Uncle!!
Re: Emergency!!!!
check with recovery manager.. and try re-installing software in the advanced options..
13-11-2007, 07:50 PM
Re: Emergency!!!!
machine is not booting up.
13-11-2007, 07:53 PM
Rubik's Uncle!!
Re: Emergency!!!!
what!!!  .. what did you do dude..
13-11-2007, 07:55 PM
Re: Emergency!!!!
c'mon man....can u send me that ndisrd.sys file....
13-11-2007, 08:01 PM
-----ATi-----
Re: Emergency!!!!
what is the use if someone sends you the file if your comp is not booting???
http://twitter.com/akshayms
Dreamweaver
Re: Emergency!!!!
Man.. is the laptop still under warranty period ?
Re: Emergency!!!!
i am trying to make a msdos boot disk...won't that work?
13-11-2007, 08:05 PM
Rubik's Uncle!!
Re: Emergency!!!!
LOL dude that file ndisrd.sys is a virus .. google it ..
I guess no option other than Full Recovery
Dreamweaver
Re: Emergency!!!!
Well, u say that u cant boot... so what exactly is the message u are recieveing ?
"ndisrd.sys missing?"
13-11-2007, 08:06 PM
Re: Emergency!!!!
yes but i'll have to take it to the US
alrite...ppl I need ntdetect.com, boot.ini, and ntldr... I have the bootmgr, BCD files from my recovery disk.....can someone send me that?
prash.siv@gmail.co
this id is meant for that....
13-11-2007, 08:08 PM
Dreamweaver
Re: Emergency!!!!
dont give ur mail ID in public please..
13-11-2007, 08:13 PM
Re: Emergency!!!!
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem:
1. Insert your windows installation disc and restart your computer
2. choose your language settings and click "next"
3. click "repair your computer"
If you donot have this disc. contact your sysadmin or computer manufacturer for assistance.
File: NDISRD.sys
Status: 0xc0000098
Info: WIndows failed to load because a required file is missing, or corrupt.
13-11-2007, 08:14 PM
Rubik's Uncle!!
Re: Emergency!!!!
^^ dude its a virus,
13-11-2007, 08:20 PM
Re: Emergency!!!!
prash.siv@gmail.co
this id is exclusively meant for the public
I did google for it buddy.....and isaw that that it was a virus... but u have any ideas? I tht....its like that svchost process....u have virus and also authentic processes with that name
@charan....the link u sent says......its a packet redirector driver...is that supposed to be a virus?
Reason: Automerged Doublepost
13-11-2007, 08:22 PM
Rubik's Uncle!!
Re: Emergency!!!!
^^ yea goof up from my side.. sorry for that link..
13-11-2007, 08:26 PM
#19 (permalink)
Re: Emergency!!!!
i feel like crying out loud....waaaaahh
13-11-2007, 08:33 PM
#20 (permalink)
Dreamweaver
Re: Emergency!!!!
Bro install XP
13-11-2007, 11:43 PM
#21 (permalink)
Re: Emergency!!!!
ppl I need ntdetect.com, boot.ini, ntldr, NDISRD.sys files...please send em ..... prash.siv@gmail.com
14-11-2007, 09:09 AM
#22 (permalink)
Re: Emergency!!!!
hmm. Just format it if its possible. In case you have data then go to a nearby COp Shop and he will clean the Virus for a minimal or no charge.
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
14-11-2007, 03:27 PM
#23 (permalink)
Re: Emergency!!!!
its not a virus dude.....
can someone send me the files?
14-11-2007, 10:44 PM
#24 (permalink)
Proud to be Linux
Re: Emergency!!!!
i can send them but i'am very busy.could you wait until tomorrow evening???
got to reboot my pc an start windows after 3 long months of linux use.
hey but boot.ini file varies from pc to pc.i depends on which partition you have installed windows.
http://abhinandh.com
14-11-2007, 11:09 PM
#25 (permalink)
Re: Emergency!!!!
Hey thanks a lot. You send me the files. I'll edit the boot.ini file.
14-11-2007, 11:34 PM
#26 (permalink)
TechTin.com
Re: Emergency!!!!
you have a HP laptop.
Call HP customer care at :
1800-1122-67 (toll free from MTNL and BSNL)
They will guide you in best possible way.From there take your local service center address.....and visit service center.You can get free service, if it is in warranty (regarding country, I am not sure).
But, If there is any matter of country...than will will charge something..but will give you best service.
15-11-2007, 10:20 AM
#27 (permalink)
Re: Emergency!!!!
contacting customer care was the first thing I did....I know more than waht they could tell me....But yeah they gave me a maual on how to remove the hard disk from the laptop......
15-11-2007, 10:28 AM
#28 (permalink)
TechTin.com
Re: Emergency!!!!
why dont you visit local HP service center once.
15-11-2007, 10:38 AM
#29 (permalink)
Re: Emergency!!!!
simple reason.....cause it costs me....
This problem can be solved very easily if I shell out 500 bucks.
I need to buy a laptop harddisk dock to connect to my desktop via USB, transfer data to my external hdd.....use the recovery disk to format and reinstall vista.....
But I don't want to spend...I can get a 2GB pendrive for the money.
I'd rather boot in MS-DOS mode copy the file abhinandh gives me and hopefully everything should work.
and yeah....I contacted the HP customer care online and they gave me the soln 1...(using the external dock)
15-11-2007, 05:27 PM
#30 (permalink)
Cool as a CUCUMBAR ! ! !
Re: Emergency!!!!
download those required files from HERE ....
& work on ur lappy ........
... W H O T ...
Search this Thread |
