Old 12-11-2007, 08:33 PM   #1 (permalink)
Dreamweaver
Gigacore's Avatar
Default Digit Not Opening
Hi guys,
I cant open digit forum and website from my computer! Please help me!
I can open all other sites. But even i cant ping successfully to digit!
It says connection timed out.
I cleared the cache, i cleared the temp internet files, i tried on other browsers. none seems to work
PLEASE HELP ME.
I posted this from opera mini
no one to help?
bump, please help me
Gigacore is offline
Old 13-11-2007, 01:11 AM   #2 (permalink)
Default Re: Digit Not Opening
its fine here.
try using some proxy, if it fails then some serious problem is there with isp
Faun is offline
Old 13-11-2007, 01:17 AM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
What ip address does it shows when you try to ping thinkdigit ..??
Try this :
Start > Run > Cmd {Press Enter}
ipconfig /flushdns {Press Enter}
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 13-11-2007, 03:01 AM   #4 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
sometimes happened with with me too in the past
गीक होना माँगता
victor_rambo is offline
Old 13-11-2007, 07:29 AM   #5 (permalink)
Dreamweaver
Gigacore's Avatar
when i pinged to thinkdigit.com the IP is 198.65.131.97
them i'll get request timed out in all the four attempts and finally it says 100% loss.
after i did ipconfig /flushdns
i got, "Succesfully flushed the DNS Resolver Cache"
now what to do?
Gigacore is offline
Old 13-11-2007, 08:01 AM   #6 (permalink)
Jai Suresh
lywyre's Avatar
I aint sure, but try chaning one of your DNS address to that of OpenDNS:
i) 208.67.220.220 [or]
ii) 208.67.222.222
I have set my Primary DNS to OpenDNS : 208.67.220.220 and
Secondary DNS to BSNL : 61.1.96.69
So, I almost am never locked from DNS Problems.
lywyre is offline
Old 13-11-2007, 08:19 AM   #7 (permalink)
Dreamweaver
Gigacore's Avatar
well i changed the dns, but still its not working
Gigacore is offline
Old 13-11-2007, 08:33 AM   #8 (permalink)
left this forum longback
praka123's Avatar
@gigacrore:it is weird but do u have some fw rule set knowingly or unknowingly in ur system to block 198.65.131.97 ?try pinging after stopping ur firewall.(just for test) sure some internet suite or something u installed blocks 198.65.131.97
also do u have a linux install too na?try from linux too.
and try in cmd "traceroute 198.65.131.97"
mine shows:
prakash@gutsy:~$ traceroute 198.65.131.97
traceroute to 198.65.131.97 (198.65.131.97), 30 hops max, 40 byte packets
2 218.248.255.70 (218.248.255.70) 28.135 ms 30.567 ms 33.007 ms
3 218.248.255.70 (218.248.255.70) 35.467 ms 37.917 ms 40.356 ms
4 203.101.65.181 (203.101.65.181) 43.522 ms 46.708 ms 48.665 ms
5 125.21.167.74 (125.21.167.74) 50.859 ms 54.051 ms 56.734 ms
6 217.6.50.109 (217.6.50.109) 323.325 ms 286.115 ms 287.222 ms
7 p4-1-2-0.r22.londen03.uk.bb.gin.ntt.net (129.250.8.5) 289.415 ms 295.720 ms 295.996 ms
8 p64-2-1-0.r21.nycmny01.us.bb.gin.ntt.net (129.250.2.38) 295.010 ms 297.440 ms 299.641 ms
9 as-0.r21.asbnva01.us.bb.gin.ntt.net (129.250.2.9) 310.718 ms 314.143 ms 324.725 ms
10 xe-1-2.r03.stngva01.us.bb.gin.ntt.net (129.250.2.19) 319.282 ms 320.488 ms 322.683 ms
11 mg-2.c20.stngva01.us.da.verio.net (129.250.26.204) 325.123 ms 326.837 ms 329.740 ms
12 161.58.156.189 (161.58.156.189) 292.319 ms 293.040 ms 294.034 ms
13 logistics20.com (198.65.131.97) 295.959 ms 298.890 ms 300.842 ms
praka123 is offline
Old 13-11-2007, 09:47 AM   #9 (permalink)
Dreamweaver
Gigacore's Avatar
i'll try disabling the firewall. . . . i dont know how to configure EVDO in Ubuntu
even after turning off the firewall i cant ping! and i tried on fresh installation of XP in other partition. even its not working there too
please help me
WTF?
Now i can access the forum using a PROXY SERVER.. why not directly ?
Gigacore is offline
Old 13-11-2007, 10:28 AM   #10 (permalink)
please help me
WTF?
ur friends havin same connection facing same problem ??
Faun is offline
Old 13-11-2007, 11:13 AM   #11 (permalink)
Dreamweaver
Gigacore's Avatar
none of my friends has this connection. i'll contact ISP this evening.
anyway thanks for the help guys
Gigacore is offline
Old 14-11-2007, 05:02 AM   #12 (permalink)
Well .. Check your hosts file anyway .. :
C:\Windows\System32\drivers\etc\
You'll find a file called hosts here, open it in notepad and check it ..
Digit Dec. DVD is'nt Opening... Pradeep Kashyap QnA (read only) 2 09-12-2006 07:53 AM
Where can I find Prevous Digit pdfs in Digit Dec-05 mag DVD nawaz123 Software Q&A 2 09-03-2006 11:35 PM
[Feedback] March 2005 Digit DVD/Digit Magazine Byte Feedback 35 04-04-2005 11:22 PM
[Feedback] Jan 2005 Digit DVD/Digit Magazine Byte Feedback 45 30-01-2005 05:00 PM
