Old 23-03-2005, 11:37 AM   #1 (permalink)
Default AVG 7(free) control center icon disappears from system tray
hi,
I am using AVG 7 free antivirus edition ,one day my AVG control center icon in system tray disappeared suddenly .
And i couldnt see that again in my system tray .I could see that avg_cc (control center .exe file )gets started up during system boot start .
But peculiar thing is that avg gets updated automatically when connected to internet .How is that happening with out Control center icon being dispalyed in system tray ???
Why what happened , i couldnt understand ..is this any virus in background ???
pls any avg 7 users help me out to handle this .
regards,
lajs is offline
Old 23-03-2005, 01:30 PM   #2 (permalink)
swatkat's Avatar
Check this, go to Start> Run and type msconfig and press ENTER.
Here in StartUp tab, the AVG_CC entry should be selected/checked.
Also, can you bring the Control Centre from AVG Test Center Window? ( Open the AVG Test Center Window by double clicking it's icon in Desktop or from Start Menu). From here, Open the Control Center through the menu. Does Control Center opens up?
http://swatrant.blogspot.com/
swatkat is offline
Old 23-03-2005, 03:05 PM   #3 (permalink)
if swatkat's ways dont work then u might have been trojaned..
h4xbox is offline
Old 25-03-2005, 11:03 PM   #4 (permalink)
hey i could see in start up ...but couldnt see in tray ..
even if i try to start it from start->program
mouse pointer acts indicates as if it has opened the program but i could nt see control center visually in screen ...
That control center module doesnt popups in screen visually ..
iam using kerio firewall , is it doing any activity at the background.
lajs is offline
Old 25-03-2005, 11:15 PM   #5 (permalink)
swatkat's Avatar
hmm....i think Firewall is not the problem.
Something is blocking AVG CC from opening or some files are corrupt!
Try to open the Control Center through the AVG Test Center (using Desktop icon or Start> Program icon) in SAFE Mode, does it open there?
If it does not, then you have to uninstall it and reinstall a new copy.
http://free.grisoft.com/
swatkat is offline
Old 25-03-2005, 11:41 PM   #6 (permalink)
i think i have to reinstall it .....coz other option u mention doesnt seem to work
but iwant to know onething ...if i reinstall will all my updates get deleted ????
lajs is offline
Old 25-03-2005, 11:53 PM   #7 (permalink)
swatkat's Avatar
If you download a new copy from the WebSite, then there is no need to update it now.
But if you are installing from an old AVG Setup , then you need to get the updates again.
swatkat is offline
Old 26-03-2005, 12:02 AM   #8 (permalink)
hi am a dialup user ..my AVG have downloaded latest updates till now ....
if i have to download setup from net again ...i think it would take away my time ...is this only available solution ....
anyway thanks for u r help !!
lajs is offline
Old 26-03-2005, 08:15 AM   #9 (permalink)
Hi,
Unfortunately yes. Uninstall-reinstall.
DH.
Where is the wisdom we have lost in knowledge?
Where is the knowledge we have lost in information? - (Choruses from the rock - T.S. Eliot)
Doc Holliday is offline
