Old 11-11-2007, 04:48 PM   #1 (permalink)
Default Samsung YP-K3 Review!
Its a birthday gift from me to me!!
Price: 6K
Features:
FM Tuner, 2GB or 4GB (i have 2 GB) memory, 20 Hrs battery life, Photo viewer, Text Viewer, Customizable Equalizer.
Design:
Very sleek, front panel is scratch proof and has a glossy look... this makes fornt panel get finger prints, which can be wiped off easily, but looks ugly!! Back Panel is not so scratch proof, n already has some scratches.... whole body is surrounded by a silver frame. It has 7 touch buttons, and a mechanical button (on/off) on the right side. It has 3.5mm jack n 24pin samsung standard connector!
User Interface
UI is simple to use and nobody should have problems using it!!
FM Tuner
It can only be tuned when a 3.5mm jack is connected n this can be anything, its just needs to be connected to a 3.5mm jack.
Battery Life
It can only be charged through USB port on ur PC, company says that too with their propreitary cable...didnt try with AC to USB connector (will try after exams).
Text Viewer
Only txt files and that too word wrapping is not so good.
Sound Quality
Its just fabulous, bundled earphones does their job pretty well. Get a better earphones n njoi more
Display
Touch screen is very sesnsitive although, a lock button is provided. Slide the power button in opposite direction n it gets locked. Since the display is not so good, photo viewing is not completely a thrilling experience
Cons
No dedicated Volume Keys
No Album Art
No playlist editing
Be sure to update ur firmware after u buy it if necessary, else Customizable EQ or Zoom Function and few other features wont be avavilable.
i m absolutely in luv with this player!!
other alternatives can be sony nwb100 series and creative zen v plus
Its my first review....
Shwetanshu Srivastava
shwetanshu is offline
Old 11-11-2007, 04:51 PM   #2 (permalink)
sam_1710's Avatar
Default Re: Samsung YP-K3 Review!
Wow.. thanks for the review.. i was lookin for samsung's players.. ..
But u forgot the most important factor.. Wats the Cost? ..
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202
sam_1710 is offline
Old 11-11-2007, 05:39 PM   #3 (permalink)
Dreamweaver
Gigacore's Avatar
No album art ... anyway.. thanks for the review
Gigacore is offline
Old 11-11-2007, 06:32 PM   #4 (permalink)
hehehehe 6k after discounts!!
Samsung D500 Review hbk88in Mobiles and Tablets 28 02-06-2008 10:00 AM
SamSung 226BW Review rajesh201985 QnA (read only) 7 19-10-2007 02:58 PM
Samsung 740N: short review goobimama QnA (read only) 1 28-04-2007 03:51 PM
The Cheapest Slider ever...Samsung E630 (Review) hbk88in QnA (read only) 3 19-04-2005 02:45 PM
Samsung C100 review. cheetah Reviews 29 08-03-2005 02:09 AM
