Old 10-11-2007, 01:13 PM   #1 (permalink)
sona's Avatar
Default Difference between dual core and core 2 duo
While visiting some IT pages,i found 2 kinds of processors:dual core and core 2 duo-whats the difference between them....???
adn
sona is offline
Old 10-11-2007, 01:23 PM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: Difference between dual core and core 2 duo
The these both processors have only 2 cores, the major difference is the bandwidth.. i.e the speed the core 2 duo offers is enourmous than that of the dual cores... The C2D has more room for Level Cache. Apart from Dual Cores and C2D, Pentium D is nothing but, two prescotts running together side by side.. Its very HOT! So u cant expect more over clocking... but the C2D is made with revolutionary 65 nm fabrication process.... which runs cool and good for overclocking...
Please correct me if i'm wrong
Gigacore is offline
Old 10-11-2007, 01:48 PM   #3 (permalink)
Nav11aug's Avatar
^ Not very precise.
Any processor having two cores is called "a dual core" processor. Example: Core Duo, Core 2 Duo, Pentium D ,Athlon64 X2 etc.
However Core 2 Duo is a architecture. It is a IC design ,simply put.(Though that would be a gross understatement, to tell an Intel engineer, "Oh ,just an other circuit " )
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 10-11-2007, 01:59 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
Just check out the numerous theads below
infra_red_dude is offline
Old 15-11-2007, 05:25 PM   #5 (permalink)
sona's Avatar
So it means that in both pentium D and core 2 duo.....There are 2 separate processors running side by side.....But then How does the performance differ,,,????
adn
sona is offline
wats diff between dual core n core 2 duo reddevil2 Hardware Q&A 8 25-07-2009 10:27 AM
want to know difference b/w Dual core and Core 2 Duo sakthirajesh Hardware Q&A 10 31-10-2007 09:33 PM
diff between Intel dual core,Core 2 , Duo?? NagpurDaMunda CPU / Motherboards 26 21-07-2007 06:37 AM
Intel dual core without HT or AMD64 dual core--which is best vps85 CPU / Motherboards 2 26-04-2005 01:02 AM
