Old 10-11-2007, 12:45 PM   #1 (permalink)
An Esoteric Geek
sridatta's Avatar
Default Suggest me an Image to Text converter
I would like to convert a gif image containing some text into ascii text...
Please suggest me a converter for this..
Thanks
sridatta is offline
Old 10-11-2007, 01:31 PM   #2 (permalink)
sam_1710's Avatar
Default Re: Suggest me an Image to Text converter
already discussed in the forum.. please search b4 starting a new thread!!!
btw.. u can try : http://asciiconvert.com/
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202 :)
sam_1710 is offline
Old 10-11-2007, 01:36 PM   #3 (permalink)
Nav11aug's Avatar
+1
even this might help/.. chk i out http://www.glassgiant.com/ascii/
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 10-11-2007, 01:45 PM   #4 (permalink)
An Esoteric Geek
sridatta's Avatar
I dont want an ascii art converter.. I want the software which convert text in images to ascii text format.. (Optical Character Reading)
sridatta is offline
Old 10-11-2007, 01:53 PM   #5 (permalink)
sam_1710's Avatar
oh.. my bad..
Sorry i cudn't help u on dat!!
sam_1710 is offline
Old 10-11-2007, 01:56 PM   #6 (permalink)
Nav11aug's Avatar
same .. _damn_
Nav11aug is offline
Old 10-11-2007, 02:12 PM   #7 (permalink)
sam_1710's Avatar
found this software thru google..
It recognised O, L and some other stuff.. but not accurate !! Interface also isnt dat appealing!!
download from here : http://www.download3000.com/download_5614.html
EDIT:It works too good with Black text on white background.. preferably with default fonts like arial, courier..etc..
This is the text i chose to select..
Then select "Native text select" or "native text/graphics select Window"
This was the selected text
@article{ aas95text,
author = "K. Aas and L. Eikvil and T. Andersen",
title = "Text Recognition from Grey Level Images Using Hidden {Markov} Models",
journal = "Lecture Notes in Computer Science",
volume = "970",
pages = "503--??",
year = "1995",
url = "citeseer.ist.psu.edu/aas95text.html" }
*** We appreciate your suggestions at support@CaptureText.com ***
sam_1710 is offline
Old 10-11-2007, 02:18 PM   #8 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: Suggest me an Image to Text converter
I got one with My Scanner
it work best for me
its
ABBYY FineReader 5.0 Sprint
http://www.abbyy.com/download/?param=28844
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 10-11-2007, 04:44 PM   #9 (permalink)
An Esoteric Geek
sridatta's Avatar
it work best for me
its
this software is awesome... this is want i exactly wanted...
Thanks a lot.. !!!
sridatta is offline
Photoshop:Text, with image as filler (vid) karnivore Tutorials 2 03-09-2007 11:00 PM
Convert any image to a text image of ASCII characters amitava82 Random News 5 11-02-2007 12:46 PM
Image in text | bordered text goobimama Tutorials 5 03-02-2007 09:36 PM
<HELP> Convert PDF image to text --- ??OCR a_medico Software Q&A 2 18-03-2006 07:39 AM
How to convert image into text bharat_r QnA (read only) 5 31-07-2005 09:20 AM
