One small note though. You can obviously use the built in Ethernet on your motherboard for your connection, but I would really recommend a PCI Ethernet card instead of the built in card. So,if tomorrow some problem were to affect your line, your chances of a motherboard screw up are slightly lesser if you were to use the PCI card. You may get lucky and escape with just a fried Ethernet card instead of a fried motherboard. I wouldn't have believed such a thing was possible, but a friend of mine just had a sudden screwup with his NIC overnight. It may not have done anything to his motherboard if he'd used the onboard solution, but who knows, he didnt take the risk. He got away with lesser than 200 bucks.
@icecoolz/drgrudge: I dont think they'd be charging him for the Ethernet card anyway and 750 is just for the connection alone.
Playing FEAR XP/LSW2
