Old 22-03-2005, 03:40 PM   #1 (permalink)
Default Increase movie sound
Hi all,
I have a movie which i have copied to the hard disk.It works fine..except tht the sound is barely audible, even with the volume set to full. Is there a way to increase the sound in the movie file?
I have tried maxing the available volume options, but doesnt work!
Waiting for a reply!
<a href=\"http://150dollarsmail.com/pages/index.php?refid=bombayboy\"><img src=\"http://www.150dollarsmail.com/banner.gif\" border=\"0\" alt=\"150dollarsmail.com\"></a>
indianarchie is offline
Old 22-03-2005, 04:35 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
I have had this problem many times and i use video lan VLC player.
http://www.videolan.org/vlc/download-windows.html
It plays movie at a higher sounds
drgrudge is offline
Old 23-03-2005, 10:07 AM   #3 (permalink)
try this. open up the volume control and click the advance button and under other controls check the Loudness option.
In the keyboard of life, always keep a
finger on the ESC key
shyam911 is offline
Old 24-03-2005, 12:23 PM   #4 (permalink)
tried all tht..still doesnt work..i need to boost the sound up so i can get it to hearable levels!
Old 24-03-2005, 12:35 PM   #5 (permalink)
NikhilVerma's Avatar
Use winamp with the izotope Ozone plugin...
Using that you can boos the sound to excessive levels...
I am pretty sure that you are playing a DVD movie... Isn't it? Then the Winamp thing won't work...
NikhilVerma is offline
Old 24-03-2005, 02:40 PM   #6 (permalink)
swatkat's Avatar
Open the Volume Control Icon in System Tray, and there increase the sliders of Wave Output Balance and Four Speaker Balance to max.
http://swatrant.blogspot.com/
swatkat is offline
Old 24-03-2005, 02:42 PM   #7 (permalink)
Ethan_Hunt's Avatar
Also Try encoding ur Movie to .Avi using Virtual Dub and there it has the option of increasing Vloume of a Video
Here are the steps:
1. On the top menu bar, under "Audio", select "AVI Audio" and "Full Processing Mode".
2. If you're overlaying an audio track from somewhere else, you'll need to change the "AVI Audio" to "WAV Audio" and then select the input track.
3. After you've chosen "Full Processing Mode", you'll see the greyed-out "Volume" become available.
4. Click "Audio" then "Volume" and a smaller window will come up that says "Audio Volume".
5. Check the box that says "Adjust Volume of Audio Channels" then set the volume control slider. I find that 250% - 300% is needed for weak input audio tracks, although you get some hiss with that.
6. Click on "OK" and you're done.
Note:this will mean Converting the Entire movie into a .avi video file and with volume increased
V for Vendetta
Ethan_Hunt is offline
Old 24-03-2005, 02:47 PM   #8 (permalink)
QA Juggler
saROMan's Avatar
OK now My problem....i copied some Movies fm my frnds PC..who converted them to avi to save space....now the movie works fine..but Sound doesnot..its hardly audible.......any suggesions??
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 24-03-2005, 03:31 PM   #9 (permalink)
drgrudge's Avatar
@ saro,
Thats wht is the problem here...
Plz try VLC player..., trust me and use it and fell the difference (coz i have experience, it plays much louder)
drgrudge is offline
Old 24-03-2005, 04:12 PM   #10 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
I had similar problems with my X-Vid encoded "Band of Brothers". The sound was barely audible. Downloading and installing AC3 Filter helped.
If you are playing the movie in DivX, then this FAQ might help,
http://www.divxmovies.com/faq/#4.4
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
