To show pagefile.sys and hiberfil.sys, you need to uncheck the "Hide Protected Operating System Files" option in Tools>Folder Options>View. However, if you use the Hibernate function, keep the file and the setting, but move the pagefile to another drive. Right click the My Computer icon, select Properties>Advanced and under Performance, click the Settings button. Move to the Advanced page on the window that opens up, under Virutal Memory, click the Change button. On the window that lists all all available partitions, click the C:. and under "Paging File Size for selected drive", select the "No Paging File" radio button and then click the Set button.
Then select another partition, one that you have more space on (Preferably, if you have a second hard disk, select the first partition on it, otherwise select the one with the maximum free space) Click the "Custom Size" radio button and then select a value 2.5 times your RAM size (if your memory is 256MB then 2.5*256=640MB) and enter this value in the initial size and maximum size boxes, click Apply/OK and then restart the computer for the changes to take effect.
Playing FEAR XP/LSW2
