Old 04-11-2007, 02:41 PM   #1 (permalink)
Default Bridged mode on opensuse 10.3
yesterday i installed opensuse 10.3 on my PC.i use bridged ,ode on my MTNL DSL broadband.
guyz,please help me in configuring my connection for bridged mode.
SunnyChahal is offline
Old 04-11-2007, 02:48 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Bridged mode on opensuse 10.3
Press Alt+F2, type yast, press enter, type root password, press enter
Go to Network devices->DSL and configure form there, its easy step by step wizard
NucleusKore is offline
Old 04-11-2007, 05:18 PM   #3 (permalink)
thanx
but how to set up bridged mode?
it is for pppoe
Old 04-11-2007, 05:26 PM   #4 (permalink)
left this forum longback
praka123's Avatar
^it is in router.
praka123 is offline
Old 04-11-2007, 05:32 PM   #5 (permalink)
what??
Old 04-11-2007, 05:33 PM   #6 (permalink)
Dreamweaver
Gigacore's Avatar
mods please move this thread to open source
Gigacore is offline
Old 04-11-2007, 07:00 PM   #7 (permalink)
TheSaint
I thought you know what you were talking about when you said bridged mode. If your router is already configured in bridge mode (as you were using with your "other" operating system ) then no need to fiddle with your router.
Just go to YaST->Network devices->DSL
and run through the wizard.
You can then use KInternet to make a dialer (like the dialer in your "other" OS). It will be near the clock once activated
Old 04-11-2007, 07:01 PM   #8 (permalink)
i ran through the wizard.
but how to dial in suse?
Old 04-11-2007, 07:05 PM   #9 (permalink)
TheSaint
Install KInternet through YaST. After that if you don't see it near your clock open a shell and type kinternet to bring up the interface
Old 04-11-2007, 07:06 PM   #10 (permalink)
ok lemme try.
but let me tell u GG is far easier than suse 10.3
Old 04-11-2007, 07:10 PM   #11 (permalink)
TheSaint
Don't worry, you have to give the kinternet command only once in a terminal. This will bring up kinternet near the clock. Thereafter it automatically comes near the clock on boot, in the disconnected state off course. You have to right click on it to connect
Old 04-11-2007, 07:31 PM   #12 (permalink)
mann yhis is complicated.i have tried with both dsl and modem i configured but wohi haal hai not connecting.
cud u tell the whole process.
m a Noobie to suse
Old 04-11-2007, 07:42 PM   #13 (permalink)
TheSaint
I have done this process for a friend who has a AirTEl 512 kpbs connection like yours (dial up PPPoE). I first went through YaST-> DSL as I told you above, and entered the username and pass, and if I remember correctly the VPI/VCI too. After exiting the wizard, installed kinternet through YaST->Software management. Then opened a terminal, typed KInternet. The KInternet icon appeared near the clock. I right clicked on it to connect for the first time, browsed, tested, disconnected again by righ clicking on the icon and then closed the terminal window. There after KInternent comes near your system clock automatically at boot. You only have to right click and connect.
Enter your gateway as 192.168.1.1 in your network card properties.
Also read this
http://www.swerdna.net.au/linhowtonic.html
Old 04-11-2007, 07:45 PM   #14 (permalink)
thanx i think itll work now
openSUSE 10.3 Available Now! Dark Star Open Source 77 13-10-2007 06:57 PM
Setting up dialer for bridged mode on Vista SunnyChahal Software Q&A 13 08-10-2007 10:44 PM
PIO mode instead of UDMA mode 2 !!! PLS. HELP ME !!! rachitboom2 QnA (read only) 7 19-08-2007 10:11 PM
Difference Between FF Ordinary Mode & FF Safe Mode rajas700 QnA (read only) 9 27-08-2005 02:38 PM
what is standby mode and hibernate mode.. thegame_rulez QnA (read only) 1 16-03-2005 11:46 AM
- by tkin
