Originally Posted by technofreak
The Second problem is that While i m working on WIN XP the system restarts on its own. i hav tried reinserting the chips but it was useless. Please suggest where the problem lies & how to solve it
Your system is just 4 months old dude what CHIPS did u re - placed or re - inserting man ??
Did u repaired your mobo ?
I don't understand what CHIP u are referring to, that u
re-inserted
Anyways,
1. the problem could be due to loose Power Button Wire (connection) with the mobo, check that out.
2. the CABINET might be having some problem with the Power Button, it might not be working properly.
3. the HeatSink might not be fixed properly, try to replace the Thermal Paste and also try to put the original Intel supported fan only in case u have a different fan fitted.
4. Remove the fan and clean it ( only if u know how to do that ).
