Old 03-11-2007, 10:36 PM   #1 (permalink)
High without substance...
chicha's Avatar
Default administrator
i use vista premium home.
and i am not able to go the ADMINISTRATOR user.
i tried so many times by hitting "Ctrl+Alt+Del" but the damn thing does not work.
is it cause its not ultimate or so?
cause in XP home too there are some things missing which are there in XP Pro.
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 04-11-2007, 10:34 AM   #2 (permalink)
╬Switch╬'s Avatar
Default Re: administrator
There is no default admin user in Vista.
The account that you first made on install is by default the admin account.
Also Task manager starts by Ctrl+Alt+Esc.
There are 10 types of people. Those who understand binary and those who don’t…
╬Switch╬ is offline
Old 04-11-2007, 11:19 AM   #3 (permalink)
chicha's Avatar
thank you.
so there is no ADMINISTRATOR in any of the vista's?
and i noticed that i can not create any documents in notepad or anything like that in the Croot) i have to make a folder first.
why is that?
some new security measure? whats the harm in creating a .txt file?
chicha is offline
Old 04-11-2007, 08:24 PM   #4 (permalink)
╬Switch╬'s Avatar
Originally Posted by chicha
thank you.
why is that?
I use Ultimate and theres no admin in it too, so I think it doesn't exist in any version then.
About the text file, I don't know, maybe some security mesaure???
You could try disabling UAC and then creating files if absoultely necessary. But remember to turn UAC back on..
Hope this helps..
╬Switch╬ is offline
Administrator password for Win Xp SP2. sysfilez Software Q&A 7 21-03-2007 07:59 PM
administrator in welcome screen tanush_89 QnA (read only) 5 26-01-2007 05:26 PM
System Administrator pramod_kk QnA (read only) 2 11-09-2006 09:00 PM
CANT LOGING TO ADMINISTRATOR ON XP eureca_eureca Software Q&A 5 14-08-2005 01:55 AM
- by tkin
