LinkBack (1) Thread Tools Search this Thread Display Modes
Old 03-11-2007, 12:35 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
tweety_bird_bunny's Avatar
Question connection to wan miniport !!! :(
recently i had dis strange problem.... i hav bsnl bband.. whenever i tried to connect to internet thru my desktop, it displays followin msg " connecting to wan miniport (pppoe) " ...and it doesnt connect....the lights in router r same as those of old days. however if i connect the lan wire frm router to my laptop lan port, then it connects without any problems....
is there any chance day my desktop lan card is faulty and any way to determine it 4 sure????
i am postin dis thread thry my laptop currently...net workin fine on laptop, but not desktop...
plz guys help
tweety_bird_bunny is offline
Old 03-11-2007, 10:26 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Re: connection to wan miniport !!! :(
Go to Network Connections and check if LAN or High-Speed Internet Connection icon says connected in the second line and the lan card model is quoted in the third line.
debsuvra is offline
Old 04-11-2007, 01:50 PM   #3 (permalink)
ya it says so.... i dnt knw if lan card is corrupted or not.. cant find any way to check it... did everything... luks fine...reinstalled drivers..nothing.
Old 04-11-2007, 08:24 PM   #4 (permalink)
I get the same problem with my Airtel boradband with beetel modem. I just have to switch it off and on to make this work. Can't seem to get a proper explanation or solution to it... []
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 05-11-2007, 08:05 PM   #5 (permalink)
troubleshooter
bluepearl's Avatar
what is the error code?
try reinstalling the drivers
bluepearl is offline
Old 07-11-2007, 10:39 PM   #6 (permalink)
solved the problem.... opened cabinet...took lan card out of the pci slot...cleaned it and put it back again in the pci slot....workin fine now....
thanku guys 4 ur support...
wish u n ur family a very Happy Deewali....
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/72328-connection-wan-miniport.html
Thread connection to wan miniport !!! :( | Digit Forum | BoardReader This thread Refback 14-10-2010 08:39 PM
Want a basic mobile and connection for net connection Chetan1991 Mobiles and Tablets 5 31-10-2007 11:13 AM
which net connection should i take tanmay_rajvanshi QnA (read only) 15 16-07-2007 04:26 PM
Lan Connection sysfilez Hardware Q&A 5 12-01-2007 03:48 PM
Unable to remove PPPoE miniport -> dev. mngr legolas QnA (read only) 2 17-12-2005 03:07 PM
- by tkin
