Old 21-03-2005, 01:48 PM   #1 (permalink)
Default Stuck between Nowhere(hung PC)
have recently got a system assembled with the following configuration:
AMD 64bit 2800+ processor/ASUS K8VX Mother board/40 GB SATA HDD/LG combo/64 MB XFX NVIDIA graphics card/256MB-400 HZ Hynix RAM.
I am facing following problems:
1. The speed of the PC is increadbly slow when reading CD..
2.LG combo sometimes reads the CD I insert...sometimes it doesn't.
3. Unable to make a data disc using Nero...While wriring It says"insert
disc" while the disc is inside it...(I even tried using different discs).
4. cant open anything when A: drive is reading
5. My Computer often says (not responding.)
6. Task Manager takes ages to open.
7. Often my system hangs even if task manager says 2% CPU usage.
Please suggest remedial measures.
aerosan is offline
Old 21-03-2005, 02:48 PM   #2 (permalink)
rachitboom2's Avatar
Their 2 ways to get rid if it =>
1. Their could be some virus on your computer, so get some good antivirus and do a virus scan.
2. If the problem still occures then backup all your DATA and format and then reinstall everything again !!!
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Consoles: 3x Xbox 360 Slim 250GB Gamertag: Rachitmayhem
3x PS3 320GB Slim Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
rachitboom2 is offline
Old 21-03-2005, 04:24 PM   #3 (permalink)
are you using the IDE drivers provided in the motherboard CD? This might be the cause. Use native Windows IDE drivers.
Hope this helps!
eckswyezed is offline
Old 21-03-2005, 09:49 PM   #4 (permalink)
Hope this helps!
If it was the problem of IDE drivers then hit system would not have booted only !!!
Old 22-03-2005, 01:30 AM   #5 (permalink)
KHUBBU's Avatar
EDIT : corrected by RACHIT. My fault . I admit.
REgarding the soln, check the cables if they r loose. My DVD Rom used to stop responding sometimes but worked alright otherwise. I removed the cable and then reinserted it, problem got solved.
2nd option is to PM theraven, he might solve ur problem.
Brand new Day!
KHUBBU is offline
Old 22-03-2005, 02:34 AM   #6 (permalink)
Originally Posted by KHUBBU
which OS : win 98 or Xp ?
Hey dude read the forum Carefully !!!
he said that =>
Where will you find a Task Manager in Win 98 (it has End Task) and that to with one that shows CPU usage also ???
PLS. READ BEFORE REPLYING
Old 22-03-2005, 02:35 AM   #7 (permalink)
Well, I wil still suggest that =>
Old 23-03-2005, 11:10 AM   #8 (permalink)
download and run spybot s&d and adaware, and remove anything they find. also install the motherboard chipset drivers from the motherboard cd, and enable DMA on the cd drive.
Carnegie Mellon ECE 2007
Asus P4C800 Deluxe || 1024MB Corsair XMS ddr 400 (2-2-2-6)
Pentium 4 3.0C @ 3.5ghz || PNY 6800GT @ 410/1110
2x80gb + 120gb + 250gb = 530gb
vshah is offline
- by tkin
