The act of running a chip at a higher clock speed than it was specified for. Very often, chips are capable of running faster than they are specified for, and thus can be safely overclocked. You overclock a chip by setting it at a higher bus speed, a higher multiplier, or both. Sometimes you need to set the chip to run at a higher voltage to accomplish this, further increasing the heat output of the chip.
(¨`·.·´¨)¸.·´ ~~~ ΛMRIT~~~
`·.¸.·´ <<< If you don't stand for something, you'll fall for everything >>>
__._,_.___
www.DillDosti.co.cc
www.DillDosti-Forum.co.cc
