I was using My TV as my secondary monitor.Suddenly, I am not able to use TV as my secondary,since the Settings tab in Display properties screen do not show two monitors.It is showing properties of only one monitor (Plug and play) .How I can I restore the Display properties screen as it was before?I am using nvidia 128 Mb graphics card-P4-2.8 Ghz-512 mb ram-winxp pro.
The problem is that the video socket does a check at the time of power on and if no connection is found disables the second TV option. To solve this connect your TV to the video socket and switch it on in video in mode before you switch on the Computer. Your problem will be solved
No it wont solve the problem as I experienced the same problem earlier also!!!
start up in Safe mode and install the drivers again and then restart using your Monitor !!!
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Consoles: 3x Xbox 360 Slim 250GB Gamertag: Rachitmayhem
3x PS3 320GB Slim Gamertag: Rachitmayhem mahule_rachit@yahoo.com
