Old 20-03-2005, 08:16 PM   #1 (permalink)
Default ajeeb problem
dears all,
i am face very srange problem.
when i write data dvd than ok work is succesful but when i write vedeo dvd
than software write succeful but dvd not play or not accesable.i write data dvd of these folder VIDEO_TS & AUDIO_TS but same problem.
i use nero6608 & copytodvd304779 writing software but fail
pls help me
dinesh1 is offline
Old 20-03-2005, 08:48 PM   #2 (permalink)
enoonmai's Avatar
DVD-Video files cannot be just simply converted from one format into another oh-so-simply. Use Nero Vision Express, select Make DVD>DVD-Video and then select "Add Video Files" and then add the files you want to burn and the media type (DVD5 or DVD9). You will be automatically prompted to reduce your DVD quality to LP or EP depending on the media size. Select "Video Options" and then decide your output format (India-PAL) and your aspect ratio, whether its 4:3 or 16:9 widescreen. You can even create the DVD menu and its play/display options. Once you enter all settings, NVE will automatically transcode your DVD-Video and burn it on to the DVD.
Playing FEAR XP/LSW2
enoonmai is offline
Old 20-03-2005, 10:27 PM   #3 (permalink)
tnx enoonmai,
dekhe try kar ke dekhata hu
dinesh1 is offline
- by tkin
