Old 30-10-2007, 06:33 PM   #1 (permalink)
Default encrypt a pen-drive
Hi,
I need a software which will encrypt the drive itself.
i have been searching this kind of software from a long time and i find s/w which will create a encrypted image, it will ask for password and we have to mount the image... etc..like in true-crypt ( http://www.truecrypt.org/ )
In case someone steals and just formats and uses it.
is there a s/w which will encrypt the drive such that u plug the drive to usb port and have to enter a password to access.. else NO.. thats it. Also the s/w will be in the drive itself ( this is very imp!! ) without that password the pen-drive is useless.
If anyone knows abt this kinda s/w, plz post here.
there are many thieves around, will be helpful 2 evry one.
thanks,
Mahesh
realmmahesh is offline
Old 31-10-2007, 05:45 PM   #2 (permalink)
hansraj's Avatar
Default Re: encrypt a pen-drive
i am using truecrypt.... whats wrong with that it does gives u an option of making an encrypted pen drive or removable drive and also u need not have truecrypt installed on the pc where u want to run it as it has autorun with the required files in the pendrive itself.
i suggest use that only.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 31-10-2007, 05:56 PM   #3 (permalink)
Think Zen.
ray|raven's Avatar
There came one such s/w in the HP USB Drive i purchased.
Never really tried it but AFAIK it doesnt let u access the drive unless u give the password.
I'm @ work now,but if u need i can upload it when i get home.
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 31-10-2007, 06:05 PM   #4 (permalink)
hansraj's Avatar
even i have one for my transcend pen drive but these softwares work only with the same company pendrives.... when i try to use this transcend pen drive software in the other pendrive nothing happens.
hansraj is offline
Old 31-10-2007, 06:20 PM   #5 (permalink)
even i have transcend 4 gb drive. but i cud not find the s/w. i saw in the CD, it has stuff to secure files not the drive itself. can you tell me where did you get the s/w / or cud you mail it to me plz.
thanks
mahesh
As i said earlier, if you use trucrypt and make an encrypted pen drive, you can't access the drive without trucrypt s/w in the system. in that case we have to carry trucrypt in order to make this drive working.. this method is good if u use the drive on just 2 or 3 system of ur own... nw use true crypt the other way, it makes an encrypted file.. in which our files are stored.. which has to be mounted... etc etc.. if someone steals your pendrive and formats it.. its done.. he got another pendrive!!
got my point..
- Mahesh
hi rayraven... whenever you are free plz mail me that s/w you have.. i'll hav a try.
Old 31-10-2007, 06:24 PM   #6 (permalink)
Think Zen.
ray|raven's Avatar
Sure Dude,Ill link u up to that s/w asap.
But,as hansraj has stated it might not work with other drives,
But what the heck,might as well give it a try.
Regards,
ray
Old 01-11-2007, 12:52 AM   #7 (permalink)
hansraj's Avatar
give me u r mail id , i will send it to you
hansraj is offline
Old 01-11-2007, 03:17 PM   #8 (permalink)
Think Zen.
ray|raven's Avatar
Here you go dude,
hope it works for you.
http://rapidshare.com/files/66670437...Login.zip.html
Regards,
ray
Old 05-11-2007, 06:54 PM   #9 (permalink)
Thumbs down Re: encrypt a pen-drive
i was not in station, so late..
so my mail id is
realmmahesh@yahoo.com
Originally Posted by rayraven
Here you go dude,
Regards,
ray
hi thanks for the s/w.. hmmm it doesn't work.. it says Thumb drive cannot be found, program cannot be executed..
How to Encrypt a Folder me_ankitroy QnA (read only) 3 04-04-2007 02:52 PM
Encrypt a Folder me_ankitroy QnA (read only) 1 01-04-2007 05:30 PM
Encrypt Your Email ID Trinity Open Source 4 27-08-2005 05:17 PM
Encrypt Your Email ID Trinity Open Source 1 17-08-2005 06:53 PM
Encrypt File pirates1323 QnA (read only) 1 18-03-2005 08:52 PM
- by tkin
