Old 20-03-2005, 07:25 PM   #1 (permalink)
Gaurav's Avatar
Default Icon File's thumbnails
accidently deleted the .ico file extension from folder options, now i can't see the thumbnails of these icons. Please help me restore it so that i would be able to see the thumbnail of icon files. Tried X-Setup, TweakUI and hacked into registry a little bit. Nothing helped. Using windows 98SE
Gaurav is offline
Old 22-03-2005, 02:22 AM   #2 (permalink)
sms_solver's Avatar
Just Add (type) .ico extension manually
It should solve your problem
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 26-03-2005, 12:10 AM   #3 (permalink)
Gaurav's Avatar
He He He,....... You think it's that much easy(just like that). If it had been that much easy i would'nt have posted it on this forum. Lets see who can answer it correctly. although tried your method but it did'nt help. thankx
Gaurav is offline
Old 26-03-2005, 01:01 AM   #4 (permalink)
rachitboom2's Avatar
Well dude the best method will be to install any icon editing software as it will automatically add the .ico extention when it is being installed !!!
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Consoles: 3x Xbox 360 Slim 250GB Gamertag: Rachitmayhem
3x PS3 320GB Slim Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
rachitboom2 is offline
Old 26-03-2005, 08:31 AM   #5 (permalink)
enoonmai's Avatar
Add the ICO file extension to File Types in Folder Options and navigate to
HKEY_CLASSES_ROOT\icofile\DefaultIcon
and make sure the (Default) value data is %1.
Playing FEAR XP/LSW2
enoonmai is offline
- by tkin
