29-10-2007, 03:07 PM
5 Movies, 1 DVD
Dear friends,
I have movies on my hard disk in different formats (avi, rvmb, mov, vob etc). I want to burn these movies so that i can play them on my DVD player.
I have seen DVDs with 5 movies in one disc. Please tell me how can I achieve the same.
Thanks!
29-10-2007, 03:22 PM
Dreamweaver
Re: 5 Movies, 1 DVD
its really difficult
29-10-2007, 03:26 PM
NP : Crysis
Re: 5 Movies, 1 DVD
if ur dvd player supports playing DivX encoded files, just convert all movies to .avi and burn on dvd like a data disc. most players support .avi (DivX) files
29-10-2007, 03:35 PM
Re: 5 Movies, 1 DVD
Converting to DivX is a great Idea.
I have a self burned DVD at home having 6 1CD Rip Divx Movies all in excellent quality and plays flawlessly on my 2 year old DVD Player
29-10-2007, 07:36 PM
Re: 5 Movies, 1 DVD
No. It doesn't support DivX.
and yes, it is possible. I have seen dvds of latest movies. the format is .vob but in compressed form. I don't know how they do it.
29-10-2007, 07:53 PM
Re: 5 Movies, 1 DVD
even iam facing a similar prob.... now with the broadband i have enough movies in avi format but i want to make dvd and keep it safe .... but the prob is how to make a dvd movie which fits in single layer dvd coz most of the softwares around bloat the size to some 12 gb or so when i try to convert it.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
29-10-2007, 07:55 PM
dattebayo
Re: 5 Movies, 1 DVD
try using Nero Vision. It can convert multiple avi, vob files into a single dvd with menus easily.
u will have to compromise on some quality though if ur gonna fit 5 divx movies on a single dvd5. also i Dont know if it supports real or quicktime format though.
Yoda: No. Try not. Do... or do not. There is no try.
30-10-2007, 09:36 AM
Re: 5 Movies, 1 DVD
If you have a broadband connection and have downloaded several movies in Divx / Xvid (.avi) format then i suggest DO NOT convert into DVD format as it is of no use. I suggest better buy a new DVD player supporting Divx since they are quite cheap now.
Its not worth the time and effort you spend on doing the conversion.
30-10-2007, 09:41 AM
Re: 5 Movies, 1 DVD
@rak007
do you mean that if i write those video files just as a data on a dvd with rest of my data files(such as exe, doc etc etc) even then the video files can be played on the div x player
30-10-2007, 09:54 AM
Rebooting
Re: 5 Movies, 1 DVD
Originally Posted by amitgg
Dear friends,
Thanks!
you may use DVD to AVI (xvid/ divx / MP4 / H264) encoding !! if you have a 17" Display with 1280x800 working resoltuion 1 CD DVD_RIP would be fine  means a 700 Movie without much of quality loss..
You may try combination of DVD Decrypter + AutoGK !!! there are hudreds of Tutorial available or you may try one of this on How to Make DVD to 700 MB RIP link also
rebooting
ChotoCheeta.com
30-10-2007, 04:32 PM
Re: 5 Movies, 1 DVD
Thanks mate!
31-10-2007, 12:04 PM
Re: 5 Movies, 1 DVD
Originally Posted by hansraj
@rak007
Yes thats correct !!!
I have a DVD having 5 movies
3 are in Xvid 1 CD Rip format (.AVI FILES)
1 in .vob (extracted from a pirated DVD)
1 in .mpg forrmat
i am able to play all of them in my mitashi DVD player.
The player shows an explorer like interface and you can select the movie and play it.
31-10-2007, 06:00 PM
Re: 5 Movies, 1 DVD
how much did the player cost u and when did u buy ..... i will have to check here in chandigarh...or delhi
31-10-2007, 06:21 PM
dá ûnrêäl Kiñg
Re: 5 Movies, 1 DVD
it is better to buy a dvd palyer supporting divx having ubb port so u can see films stored in the usb
The lowest rate i have seen is 1.5k supporting dvix and usb port and works flawlessly
My Stomach pains:D:D
http://tinyurl.com/32jj4m
31-10-2007, 08:21 PM
Wandering In Tecno Land
Re: 5 Movies, 1 DVD
Dear friends,
Thanks!
Just use a dual layer DVD and a Lite-On DVD Writer
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
01-11-2007, 08:39 AM
Re: 5 Movies, 1 DVD
The player is 2 years old and of Mitashi Brand. Divx was quite new then. But now most of the sub 5K players support Divx (and hence also XviD). I suggest you can go for LG, they have a good lineup. You can get cheap players like Weston too and they Do work very well but i dont know how reliable they are for long term use. But yes keep the USB port thing in mind before buying because. LG has come up recently with a USB support player but since its a new launch its a little expensive. I suggest diwali is round the corner so check out deals across electronic shops in your city and bring home a new DVD player this Diwali !!!
01-11-2007, 11:02 AM
Re: 5 Movies, 1 DVD
ok... i think time for me now to change my dvd player. This usb thing reminds me of one cable which i have. The cable has AV connectors at one end and the other end has S-video pin. now my laptop has S-video out port as well but when i connect this cable to connect my laptop and TV nothing happens.
can anyone tell me what is the reason
01-11-2007, 11:59 AM
Re: 5 Movies, 1 DVD
@hansraj
i think this is was expected. Because you cannot directly connect your computer to TV. May be you need to have an intermediate transcoder. I think the AV pins that you have may be working as follows:
The AV side goes to output of the DVD player and the S-video side as an input to the TV so that it is possible to use the DVD player with TVs not having the composite video (3 cables) option. But i am not sure about this.
Please someone correct me if i am wrong.
01-11-2007, 02:25 PM
#19 (permalink)
Re: 5 Movies, 1 DVD
ya even i came to same conclusion after wasting my Rs 250 on that stupid cable.
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Movies
Prathamesh_Mouse_Driver |
Chit-Chat |
1 |
31-07-2007 03:49 PM |
Movies to look for...
Quiz_Master |
Chit-Chat |
23 |
25-05-2007 06:57 PM |
HoW To RiP MoViEs
rakeshishere |
Tutorials |
8 |
07-11-2006 04:38 PM |
NFS UG 2 Movies
rakee |
Gamerz |
1 |
23-05-2005 03:31 PM |
