Old 20-03-2005, 09:41 AM   #1 (permalink)
The pWnster
Vyasram's Avatar
Default CD Writer Problem
I have a Samsung CD Writer. It keeps ejecting on its own all the time and it also causes errors even when written at slow speeds. HElp
Vyasram is offline
Old 20-03-2005, 10:28 AM   #2 (permalink)
enoonmai's Avatar
Samsung! HUH! Tray alignment problems. Every body faces this at times, either get a geek friend to help you fix the tray or give it to Samsung to get the tray and the lens (?) problems fixed. Better yet, if its old and you can afford it, dump it and go for a newer drive thats not Samsung.
Playing FEAR XP/LSW2
enoonmai is offline
Old 20-03-2005, 11:26 AM   #3 (permalink)
Ethan_Hunt's Avatar
Well Tray problems are now a day-to-day activity for Samsung drives.....they just wont let u take control over them i guess and instead keep on ejecting and closing at thier own will
Just Service it with the Samsung Dealer or try for a new one and dun make that Samsung.....Either make it Sony Or Pioneer
Btw the Errors need not necessarily be the Drives problem but may be caused by some Read errors from the Hard Disk too
V for Vendetta
Ethan_Hunt is offline
Old 20-03-2005, 11:27 AM   #4 (permalink)
Ignorance is BLISS !!
Samsung always gives an error 4 nothing !
It surely needs 2 be dumped
rajkumar_personal is offline
Old 20-03-2005, 04:50 PM   #5 (permalink)
godsownman's Avatar
Sometimes Samsung rectifies the problem permanently but sometimes its your bad luck .
So dont experiment with your luck trash the piece and go in for a better company as all allwyndlima said sony or pioneer.
godsownman is offline
Old 20-03-2005, 06:04 PM   #6 (permalink)
club_pranay's Avatar
well, well, well,
another day, another samsung tray problem...
today u'll get it repaired tomorrow it will be messed up again. i recommend, dont invest anything on your drive, and get a non samsung drive as soon as possible.
@mods/admins make a sticky for samsung tray problems
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 20-03-2005, 07:18 PM   #7 (permalink)
man if u cant throw away the samsung drive pls call me i would love to throw it using my hands
they are so supposed to be of the worst quality one can hear off.
Happy Computing :lol:
krishnathelord is offline
Old 20-03-2005, 10:23 PM   #8 (permalink)
- what is the error msg while burning at slow speeds ?
- if u have 2k or xp ,please post the event viewer error here
- do u have dma enabled in device manager ?
- check if u have 40 or 80 conductor cable for the drive . if its 80 , switch to 40 conductor cable and disable UDMA (but enable dma) in ur bios , if these settings are available .
- reinstall nero or ur burning s/w
- is ur writer attached to same ide controller as ur hdd or seperate , please give the details on the connection
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 23-03-2005, 02:03 PM   #9 (permalink)
hey samsung drives are all like this. they all after
some time play this **** game. in my opinion just
get it replaced by a dvd writer.
Siddhant is offline
Old 23-03-2005, 02:34 PM   #10 (permalink)
When I see someone post about a problem with a piece of hardware and someone else casually tells him to throw it out and get a replacement, I usually react with a frown. After all, the OP invested an appreciable amount of money in the hardware and telling him to junk it seems callous.
BUT in the case of Samsung CD drives, it's really the only sensible advice. Several years ago, I bought a Samsung CD-ROM drive that developed a tray problem within 3 months, and I've seen numerous others with the same problem. I told myself never again. I even sent a suggestion to Samsung about ways to solve the problem.
CD writers are relatively cheap now compared to what they cost a few years ago. If you can afford it, treat yourself to a Liteon or Sony writer.
As a stop-gap solution, if you have some mechanical skill, remove the small rubber belt that pulls the tray in and out. Go to an electronics parts shop and buy a belt that's slightly smaller. It will cost only a buck or two. That will probably cure the problem temporarily, but only for several months at the most.
pimpom is offline
Old 23-03-2005, 10:48 PM   #11 (permalink)
hey i guys i dont agree with you, i am using samsung drives from last six years, i have shifted from cd r, to cd rw, to dvd r and all the drives working with no problems at all. also samsung has the best read error correction capabilites
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 24-03-2005, 12:02 AM   #12 (permalink)
For my friend Samsung Cd-RW and CD-ROM didn't gave any problem till this date and has been working for around 3 yrs.
And dont worry Samsung Service are prompt and fast !!
Tray alignment generally starts when user pushes the tray instead of pressing the eject button to close.
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 24-03-2005, 01:04 AM   #13 (permalink)
sms_solver's Avatar
just shake the tray for a while.
As I've said earlier, never keep the tray empty! Do keep any CD (damaged will do).
This will solve the problem. I do have Samsung CDRW which is giving me same kind of problems
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 24-03-2005, 08:45 AM   #14 (permalink)
enoonmai's Avatar
@sms_solver: Keeping the tray occupied solves the random ejecting problem? I thought you said it solved the "tray does not eject" problem? In any case, do let me know as I've got a CDRW thats extremely insistent on ejecting every time you insert a CD.
enoonmai is offline
Old 24-03-2005, 11:55 AM   #15 (permalink)
I've been using Samsung CDRW 4 bout 11 months, but no probs as such. It works fine. Ya, well sometimes I get "Power Calibration error" but dat too doesn't cause n e damage 2 the media.
Another point is always use the button provided for ejecting/inserting the disks & never use the emergency exit unless there's a severe problem
I think Samsung Rulez...
detj2004 is offline
- by tkin
