Old 26-10-2007, 11:06 PM   #1 (permalink)
Knowledge Nomad
appu's Avatar
Default help related to blog
I have created a blog on blogger long time ago......i didnt update it for long time but now i am interested in it...and i am willing to post and be online for 2-3 hours for the blog.
Wat i wann know is how can i earn money wit adsense using my blog and and suggestions for improving my blog...
heres the link to it
http://4urmobileonly.blogspot.com/
just made a new one dumped the old one
appu is offline
Old 26-10-2007, 11:12 PM   #2 (permalink)
anand1's Avatar
Default Re: help related to blog
Try to concentrate on ur contents for initial months. You are definitely not going to earn in starting. Try to have large no of visitors and think for earning.
Technology On The Fly
anand1 is offline
Old 26-10-2007, 11:18 PM   #3 (permalink)
Knowledge Nomad
appu's Avatar
i wil post soon and i know that i wil not earn anything so soon.....anymore suggestions
appu is offline
Old 26-10-2007, 11:36 PM   #4 (permalink)
anand1's Avatar
try having unique contents. Clean look easily handled links and user friendly environment.
anand1 is offline
Old 26-10-2007, 11:45 PM   #5 (permalink)
Knowledge Nomad
appu's Avatar
just made a new one dumped the old one... now tell how is it ppl
appu is offline
Old 26-10-2007, 11:56 PM   #6 (permalink)
anand1's Avatar
The color sucks a bit. try to blend it.
anand1 is offline
Old 28-10-2007, 12:23 AM   #7 (permalink)
Knowledge Nomad
appu's Avatar
hey anand1 check now how is it now
also members plz check and advice me...i need ur help
I have created the blog and added content and also registered on adsense....so when wil ads start cuming on my blog??? and can some one explain this adsense working properly...i didnt understand it from the site.
Check Out My Blog for Latest Nokia N-Series Themes
appu is offline
Old 28-10-2007, 12:29 AM   #8 (permalink)
anand1's Avatar
Good now its fine
Try hands now on ur contents.
anand1 is offline
Old 28-10-2007, 12:49 AM   #9 (permalink)
Knowledge Nomad
appu's Avatar
am doing it ...wann know when wil ads appear??
appu is offline
Old 28-10-2007, 08:37 AM   #10 (permalink)
eWebGuru
ahref's Avatar
When you add adsense code, ad appears instantly.
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
ahref is offline
Old 28-10-2007, 08:43 AM   #11 (permalink)
Dreamweaver
Gigacore's Avatar
Post some more good contents...
See my blog for reference: http://santhosh.pcchitchat.com
Gigacore is offline
Old 28-10-2007, 02:36 PM   #12 (permalink)
Knowledge Nomad
appu's Avatar
ahref
i have added adsense codes from the page element option and i had registered off also...but still it hasent appeared ....does it take 2-3 days time for it to be added???
Gigacore
Checked ur blog its nice...like the template...too kool..
appu is offline
Old 28-10-2007, 02:40 PM   #13 (permalink)
Dreamweaver
Gigacore's Avatar
^ appu...... Thanks
Gigacore is offline
Old 28-10-2007, 08:21 PM   #14 (permalink)
Wandering In Tecno Land
Ecko's Avatar
http://4urmobileonly.blogspot.com//
Why not you try sites that pay u for blogging
Just google it
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 30-10-2007, 12:37 PM   #15 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
@appu ..... did u delete ur blog .......
@Gigacore ...... nice 1 ........
... W H O T ...
ax3 is offline
Old 30-10-2007, 07:29 PM   #16 (permalink)
Knowledge Nomad
appu's Avatar
nope i didnt....check it out its working...maybe there was a link problem there...have edited it......now check and give ur suggestions for it
also wann know why this is happening?
appu is offline
Old 31-10-2007, 08:29 PM   #17 (permalink)
Knowledge Nomad
appu's Avatar
any help for the above prob plz....
appu is offline
Old 01-11-2007, 09:21 AM   #18 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Try disabling Adblocker and then view your site. Ads can be seen at my side. Please check size of topmost ad...you are using 768 version but should be using 468x60 size there. Also why are you using 4 ad blocks? Google allows only 3. Since you used 4 adblocks so the 4th one is blank.
navjotjsingh is offline
Old 01-11-2007, 01:56 PM   #19 (permalink)
Knowledge Nomad
appu's Avatar
i have not installed any adblocker at all.....
and coz i havent seen my ads properly ao i dont know abt the ad placement at all....
so any help for this adblockers???
appu is offline
Old 01-11-2007, 01:59 PM   #20 (permalink)
I am Optimus Prime
Which browser are you using to see your blog?
Old 01-11-2007, 02:05 PM   #21 (permalink)
Knowledge Nomad
appu's Avatar
i have seen in opera/ie/firefox in all of them i get the same problem...no ads seen in my blog.
appu is offline
Old 01-11-2007, 02:08 PM   #22 (permalink)
I am Optimus Prime
Check your hosts file if pagesyndication.google.com url is blocked or not.
Old 01-11-2007, 02:12 PM   #23 (permalink)
Knowledge Nomad
appu's Avatar
nope its not blocked
appu is offline
Old 03-11-2007, 05:37 PM   #24 (permalink)
ax3
ax3's Avatar
yes it is blocked ....... r u surfing OFFLINE ........ check it frd ....
... W H O T ...
ax3 is offline
Old 03-11-2007, 06:45 PM   #25 (permalink)
Knowledge Nomad
appu's Avatar
i got the problem....it was the antivirus it had the ad banners blocking feature which had been turned on so that was the problem...turned it off and now i can see the ads....
anyways thnk navjotjsingh and ax3 for help.....
appu is offline
SUGGESTION: Best Blog Site for Starting a Blog Vishal Gupta QnA (read only) 43 20-09-2007 08:59 PM
Qns Related To C++ Ron Programming 20 27-08-2007 03:13 PM
n80 related the.kaushik Mobiles and Tablets 3 10-03-2007 02:35 PM
Some BLOG related queries... nithinks QnA (read only) 2 10-01-2007 09:18 AM
- by tkin
