Old 19-03-2005, 10:46 PM   #1 (permalink)
Default service pack 2 problem
I have created a XP bootable cd with service pack 2..
but when I install and enter the product key..it states it invalid....though I have installed XP earlier from the same product key without service pack2...what coukd be the problem??
can anyone help me out?
SID
Get In Touch With ME!!!!
SID
sid_b6505 is offline
Old 19-03-2005, 10:56 PM   #2 (permalink)
enoonmai's Avatar
If its a genuine CD key, then you have to contact Microsoft's technical support and tell them the problem and send them your key/COA label photo along with your registration details (the one that you used to register Windows XP with) However, if you dont have a COA label on your PC or in your manual, then its probably a pirated key and since SP2 rigorously checks for known bad keys, it wont allow you to proceed with the installation without a legal CD key.
Playing FEAR XP/LSW2
enoonmai is offline
Old 19-03-2005, 11:15 PM   #3 (permalink)
i agree with enoonmai
To solve the problem u can use key changer software for xp
Techmastro is offline
- by tkin
