Old 19-08-2004, 05:27 PM   #1 (permalink)
Default Where is the OS directory?
In windows we have "Windows" as the operating system folder, where is that in Linux? If it's not a single directory, then which are the important folders?
jnpandya is offline
Old 19-08-2004, 05:32 PM   #2 (permalink)
FooBar Guy
GNUrag's Avatar
The GNU/Linux Operating system does not use a single folder as a dump ground Here is a list of various directories and their contents...
/boot : the linux kernel and boot loader configuration files
/usr : Program files
/etc : Configuration files
/var : Mail, print web spool files
/tmp : temp directory
/home : Home directories of various users
/dev : Device files corresponding to various peripherals of your comp. (hard disk, printer, mouse, modem)
/mnt : Devices mounted onto OS to increase storage space
/lost+found : Orphan files are moved here
/root : Root's home directory
/proc : Process information pseudo filesystem.
/bin : various console utilities and apps
/sbin : system administration utilities
/lib : Shared Library files for your operating system.
Apart from these, you also have a swap partition that stores data swapped by the linux kernel.
As you can see, /etc is roughly equivalent to your windows registry. /usr can be called as Program Files directory... /boot & /lib can be called as \Windows\System32 directory. Contents of /mnt can be thought of as various drives in windows.
http://web.gnuer.org
GNUrag is offline
Old 20-08-2004, 11:03 PM   #3 (permalink)
phew...neat reply. Learnt 50% of linux here
sUlPhUr|nE` is offline
Old 21-08-2004, 07:37 AM   #4 (permalink)
The Photoshop Guy
cooljeba's Avatar
me 2
Thanks GNUrag
..:: peace ::..
Jeba
cooljeba is offline
Old 21-08-2004, 10:17 AM   #5 (permalink)
Thanks a lot GNUrag!
Actually yours was the fastest answer I have ever got on this forum! Check out the time of the both the posts. When I saw the it first, it was not this much elaborate though it was good enough to understand the structure of the OS. Then I think you might have updated it.
Could not respond as quickly as you due to down internet link. But any way, thanks again for the details.
jnpandya is offline
Old 22-08-2004, 03:08 PM   #6 (permalink)
FooBar Guy
GNUrag's Avatar
Yeah... i'd written only answer for what u asked... but later i added info for other directories...
Do you want to know more about Linux filesystems and its associated directories??? I'll add more...
GNUrag is offline
Old 26-08-2004, 12:52 PM   #7 (permalink)
Jai Suresh
lywyre's Avatar
gr8 m8
lywyre is offline
Old 26-08-2004, 01:01 PM   #8 (permalink)
Jai Suresh
lywyre's Avatar
gr8 m8
lywyre is offline
Old 26-08-2004, 11:21 PM   #9 (permalink)
lavan_joy's Avatar
great post man.thanks for the information
LAZINESS IS THE ENEMEY OF SUCCESS
lavan_joy is offline
- by Charley
