Old 24-10-2007, 06:25 PM   #1 (permalink)
Default unable to install the os
hi, when i boot to my system it will show the error invalid partition table.and then i try to install the os the files are copied correctly and the system will restsrts.then it show the same error.what can i do?please help me.i have exams on the day after tomorrow.
thecreativeboy is offline
Old 24-10-2007, 06:29 PM   #2 (permalink)
Back in Power
almighty's Avatar
Default Re: unable to install the os
post some detail of ur error with ur configration
without that no one can help u
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 24-10-2007, 06:34 PM   #3 (permalink)
Deadman Walking
Batistabomb's Avatar
that's right almighty first dont feel tense we are here to help you , write your problem clearly, whether it is WIN XP,98 or vista got this error,if so what are the partitions you have done
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 24-10-2007, 07:14 PM   #4 (permalink)
it is in windows xp.my configuration is pentium d processor.1 gbram.and intel 865 motherboard.i have five partitions.i have installed the os in c and also in d.when i try to install the os it will copy the system files in the hard disk.when the files are copied the system will restart.then i change the priority to the hard disk it will show the same error.it didnt go to the windows boot screen.
Old 24-10-2007, 07:22 PM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
priority to hard-disk u dont need to change any priority ....
pop in the cd and do as it says dont change anything
http://beingmanan.com
iMav is offline
Old 24-10-2007, 07:23 PM   #6 (permalink)
Deadman Walking
why do you installed OS on both the drives, did you installed or one drive contains OS and other the copy of files,if you had both drives installed with OS during booting the ini file is unable to choose either c or d ,so better insert your XP cd and format d drive using it, if d also has OS
Learn to live... &
Live to learn...
Old 24-10-2007, 07:25 PM   #7 (permalink)
Dreamweaver
Gigacore's Avatar
did you try fixing ur MBR?. . . YOU can do that in Recovery Console. . . read my signature
Gigacore is offline
Old 24-10-2007, 07:26 PM   #8 (permalink)
Back in Power
almighty's Avatar
yup
dont change boot priority
lets windows install completly
u can change ur priority anfter u get desktop
b4 that dont change ur booting sequence...
almighty is offline
Old 24-10-2007, 07:26 PM   #9 (permalink)
anand1's Avatar
While installing the OS go for complete formatting the drive in which you are installing the OS. Never leave the file system unaltered as it was previous. This might work.
Technology On The Fly
anand1 is offline
Old 24-10-2007, 07:35 PM   #10 (permalink)
i didnt change the priority.then it also shows the same error.ans also i ahve tried the commmands fixboot,fixmbr.
Old 24-10-2007, 07:37 PM   #11 (permalink)
iMav's Avatar
simple start from scratch ....
format the 2 partitions
get another xp cd
install again and dont change any priority ....
iMav is offline
Old 24-10-2007, 07:44 PM   #12 (permalink)
before i come to post the thread i will try it.
Unable to Install Adobe CS3 deepakprabhakaran Software Q&A 2 03-09-2007 11:01 AM
Unable to install ubuntu 6.06 catchjaga Open Source 3 12-12-2006 04:35 PM
Unable to Install RC1 akshayt Software Q&A 3 11-09-2006 11:46 PM
unable to install os abhishek_734 QnA (read only) 4 26-03-2006 10:19 AM
Unable to install opera bhavi_panchal Internet & WWW 3 05-09-2005 04:22 PM
- by tkin
