Old 24-10-2007, 02:27 PM   #1 (permalink)
High without substance...
chicha's Avatar
Default how to take screenshot of a c program.
i need to take some screenshots of the out put of my project made in "c"
i have used graphics in it.
the print screen does not work, and i tried some other softwares and still it does not work.
what to do?
i will be happy if some one could help me out by tom.
thank you.
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 24-10-2007, 08:16 PM   #2 (permalink)
Default Re: how to take screenshot of a c program.
Perhaps you can try Fraps to take video from start to end and then take a still from it...
Arun
sakumar79 is offline
Old 25-10-2007, 11:52 PM   #3 (permalink)
anzaan's Avatar
after u run the program n gt the ouput.
go to window->output
there u will find the output of ur program. copyn paste wherever u want
d a m n ! !
anzaan is offline
Old 26-10-2007, 12:13 AM   #4 (permalink)
Console Junkie
aditya.shevade's Avatar
Else use linux. Even a live CD. You can copy the output right off the terminal.
--- Console Junkie
aditya.shevade is offline
Old 26-10-2007, 07:50 PM   #5 (permalink)
chicha's Avatar
what window output dude?
could you please elobrate.
thank you.
chicha is offline
Old 27-10-2007, 09:39 AM   #6 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
do this press ALT + Enter when TC is running now u will get TC in small window mode then u can take Screenshots . I use this method
saurabh kakkar is offline
Old 27-10-2007, 12:18 PM   #7 (permalink)
sachin_kothari's Avatar
what to do?
thank you.
If you are using XP then its difficult. If you have 98 then simply PrintScrn and paste the output in MSPaint.
sachin_kothari is online now
Old 30-10-2007, 07:50 PM   #8 (permalink)
anzaan's Avatar
thank you.
after u compile (alt+f9) and execute (ctrl+f9) ur program,
go to
window->output
(i.e look for 'window' in the menu bar, then look for 'output' under it)
click on it u will get the output screen.
nw copy n paste the output
d a m n ! !
anzaan is offline
Old 31-10-2007, 03:50 PM   #9 (permalink)
troubleshooter
bluepearl's Avatar
the only way I hav found to do this is to use Linux liveCD
it doesnt work in XP
anzaan note this
when u use graphics in C program it gives blank screen in Window>>Output
bluepearl is offline
Old 31-10-2007, 04:07 PM   #10 (permalink)
anzaan note this
yes i hav noticed this phenomenon in XP.
And wats with linux live cd taking screenshot theory?
Faun is online now
Old 31-10-2007, 06:29 PM   #11 (permalink)
hi
tell me whether your problem is solved or not.. and if not tell me excatly you want to take a screen shot of a text matter or graphics
realmmahesh is offline
Old 04-11-2007, 01:19 PM   #12 (permalink)
troubleshooter
bluepearl's Avatar
A quick solution is to install Windows 98/Xp on Virtual Box
and do the print screen
If you are so much desperate for the printouts,
simply draw the things in Paintbrush !!
screenshot tanmoy_rajguru2005 QnA (read only) 10 11-10-2006 04:39 PM
need a screenshot mohit sharma QnA (read only) 5 07-11-2005 12:23 PM
screenshot saptak QnA (read only) 3 25-07-2005 10:22 PM
new program in 'close program menu' list and more....... vishakadatta QnA (read only) 2 12-04-2005 11:33 PM
screenshot ......... but how??? futuristically_ancient QnA (read only) 6 10-01-2005 05:18 PM
- by tkin
