Old 23-10-2007, 10:57 PM   #1 (permalink)
Default No plug and Play
Hi
I hav a problem with USB , when ever i plug in Flash drive i have to scan for new hardware it doesnt automatically show new drive or drive, plz help how to make it automatic.
I use winxp sp2 home.
navisangha is offline
Old 23-10-2007, 11:38 PM   #2 (permalink)
anand1's Avatar
Default Re: No plug and Play
Go to Device Manager and see if the driver for your USB especially USB 2.0 is installed or not. If not so try doing it.
Technology On The Fly
anand1 is offline
Old 23-10-2007, 11:49 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by navisangha
Hi
Update your XP from microsoft website.
ravi_9793 is offline
Old 24-10-2007, 12:19 AM   #4 (permalink)
how to install USB 2.0. I hav already updated XP
Old 24-10-2007, 12:23 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
USB 2.0 comes pre installed with XP.
Don't worry about that.
I think there is something wrong in your system.
Please do full system scan with 1 antivirus and 2 antispyware.
Old 24-10-2007, 12:24 AM   #6 (permalink)
ok. so wats the solution .. previously it was ok.. but after reinstalling windows i got this prob
Old 24-10-2007, 12:25 AM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
is the problem just after reinstallation of windows??
Old 24-10-2007, 12:28 AM   #8 (permalink)
yes
Old 24-10-2007, 12:42 AM   #9 (permalink)
TechTin.com
ravi_9793's Avatar
yes
Ok.......
Don't install using a hacked windows XP CD.You never know, what malwares n other unwanted script get installed with your XP.
Also, make sure you have atleast SP2 installed...........and If possible update your XP from microsoft website.
Old 24-10-2007, 12:51 AM   #10 (permalink)
i have a genuine XP home edition with ALL updates installed
Old 24-10-2007, 12:59 AM   #11 (permalink)
TechTin.com
ravi_9793's Avatar
Is this problem with all Flash based USb device..or any particular USB device.
Old 24-10-2007, 05:01 AM   #12 (permalink)
1. Have you tried the flash drive in all USB ports of the comp?
2. Have you tried other flash drives or MP3 players or external HDs with the USB ports? What about other USB devices like Printers, scanners, etc..?
3. Is your computer up to date with the patches?
Arun
sakumar79 is offline
Old 24-10-2007, 07:17 AM   #13 (permalink)
sourav's Avatar
there is a patch available in microsoft's website for usb 2.0, to install it, try that
but it should be installed in ur pc, anyway try that and post ur replies
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Photoshop plug-ins ! ! ! ax3 QnA (read only) 8 13-10-2006 12:47 PM
HELP Installing GamePad : Plug n Play Feature reddick Hardware Q&A 5 14-12-2005 03:38 PM
Border Plug-ins in PS CS2 linardni QnA (read only) 1 09-09-2005 06:01 PM
Plug-ins Required Choto Cheeta QnA (read only) 12 07-05-2005 11:00 AM
- by tkin
