Old 22-10-2007, 03:43 PM   #1 (permalink)
Default BIOS settings not coming
i have purchased Intel E6750, Intel original Motherboard DG33FB.
for two days it performed good.
i took it to lamington again for replacing cabinet (cause old one has some patch of rust). one day later when i went to take it back it just won't boot, even the BIOS settings is not coming.
it is showing message " AHCI BIOS is installed" when i connect my harddisk.
and " AHCI BIOS is not installed" when i disconnect it.
but not going into the settings, they have replaced the Motherboard also but for the first time it showed the settings, next time onwards it again starts the same message thing.
plz tell me what has went wrong with it.
is the motherboard and processor not compatable.
keep it cool
nd4spd is offline
Old 22-10-2007, 03:48 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: BIOS settings not coming
No Processors and Motherboard are fully compatible... try and reset the BOIS for once see if that helps
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 22-10-2007, 03:49 PM   #3 (permalink)
that is also tried i removed the bios jumper to restore bios.
but the problem remains.
keep it cool
nd4spd is offline
Old 22-10-2007, 03:51 PM   #4 (permalink)
Rebooting
If you are not running any RIAD setup and as its just few days old then once again wise thing would be taking the board to vendor again
also wait for others to reply back
rebooting
ChotoCheeta.com
Old 23-10-2007, 07:55 AM   #5 (permalink)
Removing the jumpr sets the bios to update mode afaik.You need to apply the jumper to the vacant pin and the common centre pin of the cmos jumper block,and then switch on for a couple of seconds..Or to make sure just remove the cmos battery for a few minutes and then put it back on.
If resetting doesn't help,try updating the bios.
sashijoseph is offline
Old 24-10-2007, 04:06 PM   #6 (permalink)
@sanhijoseph
I tried both the things that u have mentioned.
but it still.............. u know what.
i have read somewhere i has to do with settings in bios regarding IDE, SATAand AHCI
but i don't know which one to choose cause i have sata HDD and pata DVD-W
keep it cool
nd4spd is offline
Old 24-10-2007, 09:51 PM   #7 (permalink)
a_g = JPKN
s18000rpm's Avatar
use IDE mode.
do this if u gt BSOD or when HDD is not detected just after BIOS screen.
btw the best solution is to get it to the vendor.
btw why did they replace the m/b?
ASUS K53SV SX520D + BF3
s18000rpm is offline
BIOS settings password siddes Software Q&A 3 05-07-2007 02:24 AM
BIOS settings FOR ACPI shantanu Hardware Q&A 6 12-04-2007 04:41 AM
Bios Setup Coming Unexpectedly, Please Help Urgent bluetooth Software Q&A 4 09-07-2006 08:34 PM
Can't enter BIOS settings...Help!!! linardni QnA (read only) 15 13-01-2006 02:13 PM
C:\Documents and Settings\abc\Local Settings\temp remove it? Huzefa QnA (read only) 6 03-07-2005 10:58 PM
- by tkin
