there is some program that u start which consumes a lot resources as a result vista automatically shifts to basic to save resources
^^Heavy not only in terms of RAM and CPU usage but also in terms of GPU resources...Check GPU resources used by various tasks in Task Manager and then report....Also disable all startup programs from msconfig and then see if aero works....
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
