Old 20-10-2007, 01:51 PM   #1 (permalink)
Default Activating Standby/hibernate Option In Lenovo
Hello Guys I Got Lenovo 204822q Lappy Frm My Bschool Can Any One Tell Me How To Activate Standby/hibernate Mode There Was Link In This Forum I M Unable To Search It, Plz Provide Me With Link, And Wimax As U All Know Is New Wireless Standard Which Is Comming In India, Are Wimax Enabled Routers Or Access Points Availiable In Mumbai, If Yes Wht Is The Cost And R They Backward Compatible.thanks
Necessity is the mother of Invention
NiluGeek is offline
Old 20-10-2007, 01:56 PM   #2 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Re: Activating Standby/hibernate Option In Lenovo
Which OS is it?
about.me/gxsaurav
gxsaurav is offline
Old 20-10-2007, 02:01 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Are you using windows XP
Wait dear..dont be in hurry..Wi-max technology is still to come in action.And I dont think , hardware required is available anywhere in India.
ravi_9793 is offline
Old 20-10-2007, 02:13 PM   #4 (permalink)
Web developer
narangz's Avatar
I am assuming you are using XP. You can enable hibernate mode from control panel:
Start->Control Panel-> Power Options
Here click on Hibernate tab & select Enable Hibernation.
To get Hibernate option after clicking Shut Down, press & hold 'Shift' on keyboard if Standby option is displayed.
If you do not get Standby option then all drivers might not be properly installed.
narangz is offline
Which one draws more power standby or hibernate? ajaybc Hardware Q&A 7 08-10-2007 06:03 PM
Cant Hibernate or standby aninnovator Software Q&A 2 31-05-2007 01:41 AM
hibernate & standby ! ! ! ax3 QnA (read only) 11 28-08-2005 01:10 PM
What is the differemce between Standby & Hibernate bharat_r QnA (read only) 7 18-05-2005 07:43 PM
Unable to hibernate /standby bhare ka tattoo QnA (read only) 2 21-12-2004 11:40 PM
- by tkin
