Old 19-10-2007, 08:38 PM   #1 (permalink)
sourav's Avatar
Default Help! ZoneAlarm
whenever i start zone alarm i cannot connect through network to internet.
I have installed zone alarm in the desktop. This connects directly to internet.
My laptop connects to internet through this. i am not able to connect to net through this
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 19-10-2007, 08:45 PM   #2 (permalink)
Back in Power
almighty's Avatar
Default Re: Help! ZoneAlarm
didnt get u?
U ve one lappy and one desktop? ryte
U installed za on desktop? ryte
and u want connect with desktop using za???
u need to put ur lappy in internet zone not in trusted zone
i think u add ur lappy in trusted zone
check it
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 19-10-2007, 08:56 PM   #3 (permalink)
sourav's Avatar
YUP
IF I ADD IT IN INTERNET ZONE THEN I AM NOT ABLE TO SHARE FILES
sorry
for uppercase
sourav is offline
Old 19-10-2007, 08:59 PM   #4 (permalink)
Back in Power
almighty's Avatar
go to firewall>main>intenet security zone>custom>Internet zone (tab) and select all
this ll work
try it
almighty is offline
Old 19-10-2007, 09:03 PM   #5 (permalink)
Attitude matters
Ponmayilal's Avatar
yep click on the firewall tab of your Zonealarm and add the IP address of the Modem/router, Desktop,and the laptop to the trusted zone.That is what I have done and I am able to share files.
Ponmayilal is offline
Old 19-10-2007, 09:05 PM   #6 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Thumbs up Re: Help! ZoneAlarm
Originally Posted by sourav
YUP
sorry
for uppercase
That's Right internet Zone means no sharing
Put your lap in Trusted & internet conn in internet
Now you'll share as well as block intrusions
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 19-10-2007, 09:16 PM   #7 (permalink)
sourav's Avatar
help me
when i shutdown zone Alrm i am able to do everything
and i don't want o uninstall zonealarm
and when zone alarm is running at that time my lappy is not able to get net.
i tried with trusted zone and internet zone.
after shutting down zone alarm it works
sourav is offline
Old 19-10-2007, 09:25 PM   #8 (permalink)
Attitude matters
Ponmayilal's Avatar
For my wireless network I have not added any IP address in Internet properties of the Desktop but only in the Zonealarm firewall.
Old 19-10-2007, 10:03 PM   #9 (permalink)
Ecko's Avatar
Lightbulb Re: Help! ZoneAlarm
help me
Zone alarm will ask for the zone of connection as soon as you connect the Laptop with desktop & also when u connect desk with net
Just make lap as trusted & reduce the trusted zone setting to least
Make Int. to inernet zone & make setting to max
Ecko is offline
Old 19-10-2007, 11:48 PM   #10 (permalink)
have u allowed basic services to access the Net?
Generic Host Process for Win32 Services(svchost.exe)
Userinit
Firefox/IEx
Is there a lock sign at the taskbar?
W i d e S c r e e N is offline
Old 20-10-2007, 09:13 AM   #11 (permalink)
Attitude matters
Ponmayilal's Avatar
Sourav has reported that by disabling the Zonealarm, he is able to do everything. So it is quite clear Zonealarm is blocking. To resolve the problem he should add the ip address of the modem/router, desktop and laptop in the trusted zone of the Zonealarm firewall, most probably 198.162.1.1, 198.162.1.2 and 198.162.1.3 and try.(it can be 192.168.0.X, depends on the modem/router)
Old 20-10-2007, 03:17 PM   #12 (permalink)
sourav's Avatar
my laptop's ip address depends upon dhcp or it is automatically assigned
sourav is offline
Old 20-10-2007, 06:01 PM   #13 (permalink)
Attitude matters
Ponmayilal's Avatar
Good that you are listening. I presume that you have in the Internet protocol (TCP/IP) properties of your Local Area connection in the Desktop, have ordered it to obtain the IP addresses automatically. In that case you would have turned the DHCP server functionality in your modem/router on.You can in the LAN settings of your modem restrict the DHCP server to assign IP addresses upto 192.168.1.3 instead of any upto 192.168.0.253. That way your Desktop and Laptop won't get anything other than 192.168.1.2/3.So include from 1 to 3 in your Zonealarm's trusted IP addresses.Zone alarm>firewall>zone>add.
Instead of adding individulal IP addresses you can also add them in the range say 192.168.1.1 to 192.168.1.3. That is all to it.
If you do not want to enter into your modem and change the settings simply add the range 192.168.1.1 to 192.168.1.253 to the Zonealarm's trusted zone.I will however not recommend this for security reasons.
In my wireless network, I have further linked the MAC address of each PC to the IP address that can be assigned to it by the modem/router/ access point. That way my desktop always gets 192.168.0.2, my Vista Lappy 192.168.0.3 and my Mediacenter PC 192.168.0.4.This apart from the WPA2 security.So no outsider even within the wireless range can draw juice from my internet connection/PCs. As in your case my Desktop (XP) is the main PC directly connected to the modem/router and protected by Zonealarm. And make sure to disable the windows firewall. Hope I have made things clear to you. Good luck.
Old 20-10-2007, 09:45 PM   #14 (permalink)
sourav's Avatar
my desktop is assigned 192.168.0.1, it directly connects to internet, and my laptop to it through LAN but remember it is a two computer connection only, so there is no router. my laptop is assigned buy DHCP for its address
sourav is offline
Old 21-10-2007, 12:56 AM   #15 (permalink)
Attitude matters
Ponmayilal's Avatar
I am afraid that you are using ICS (Internet connection sharing) of the bygone days.Most modems though not a router in the conventional sense, have built in router functions such as DHCP server and this may be conflicting with your ICS setup.If your Host Desktop computer takes on as the gateway with the IP address 192.168.0.1 and assigns the IP address to your lappy (In this case your host computer acts as the DHCP server) you must surely disable your modem acting as the DHCP server etc.Access your modem page and turn off the DHCP server in its LAN setup and then check.Make sure that your modem's IP address itself is not 192.168.0.1. If it is change it to 192.168.1.1.In your TCP/IP properties page of Local Area Connection of your host Desktop computer make sure you give the IP address as 192.168.0.1, subnetmask 255.255.255.0 and gateway address as 192.168.1.1.Add 192.168.1.1 (modem's IP address) and the range 192.168.0.1 to 192.168.0.253 in your zonealarm's trusted zone and then check. These are my thoughts.I cannot assure you that this will definitely resolve your problem but no harm in trying.Good luck.
Old 21-10-2007, 11:58 AM   #16 (permalink)
sourav's Avatar
i connecting to net through tata indicom's wireless connection
anyway, i will again say you the results after seeing this
sourav is offline
ZoneAlarm Must Be Updated Now! Third Eye Technology News 4 05-05-2007 11:53 PM
Avast Or Zonealarm artem QnA (read only) 14 25-10-2006 02:05 PM
Zonealarm Features?? kool Software Q&A 4 26-09-2006 08:56 PM
ZoneAlarm 6 ! ! ! ax3 QnA (read only) 11 13-11-2005 08:40 AM
About Zonealarm saROMan QnA (read only) 4 15-02-2005 11:58 AM
- by tkin
