Old 19-10-2007, 01:21 PM   #1 (permalink)
krazyfrog
Posts: n/a
Default Unable to set themes. Help needed.
I downloaded a few themes from InterfaceLIFT for my Windows pc. However i've no idea how to set them .
I tried going to display properties and setting them from there. However I don't see the theme files when i browse through display properties .
The themes that i downloaded were zip files which contained one *.msstyles file and a Shell folder having some *.dll files .
Please guide me to set these themes .
Old 19-10-2007, 02:23 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Unable to set themes. Help needed.
1) Unzip the downloaded file.
2)Now copy paste all to "%windir%\Resources\Themes\" folder.
3) Now you will be able to find the theme in display properties.
If you still cant change theme, than you need to install a patch after which you can install theme.Download from here:
http://www.osx-e.com/downloads/utilities/patcher.html
ravi_9793 is offline
Old 19-10-2007, 03:51 PM   #3 (permalink)
krazyfrog
Posts: n/a
Tried that. But still doesn't work. Thanks anyway.
Old 19-10-2007, 03:53 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
You need the uxtheme patcher. You need to patch it and then do what Ravi said. Find the uxtheme patcher here: http://www.softpedia.com/get/System/...iPatcher.shtml
infra_red_dude is offline
Old 19-10-2007, 03:53 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
After installing patch..just double click on *.msstyles file .
Your theme should change.Else may be downloaded theme is crupt.
Old 19-10-2007, 04:04 PM   #6 (permalink)
krazyfrog
Posts: n/a
^^ Yes finally worked. Thanks a lot dude!
Old 19-10-2007, 04:08 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
my pleasure brother
Themes google360beta QnA (read only) 2 22-10-2005 09:36 AM
Unable to save webpages in some websites ??? help needed Yoda QnA (read only) 2 28-01-2005 05:18 PM
Unable to disbale Windows XP firewall. Help Needed. Yoda Software Q&A 5 25-01-2005 11:16 AM
Should Windows XP themes be included on themes section? Kiran Software Q&A 22 11-04-2004 01:12 PM
- by tkin
