Old 18-03-2005, 03:40 PM   #1 (permalink)
mayank76
Posts: n/a
Default how to remove instant access dialer
Dear sir,
I am in great problem please help me, I am running my computer on p4 2.4, 512 mb ddr ram, an ati radeon 9600se graphic card. I have two 40 gb hard disks ,I have installed winxp and win98 on different hard disks. I use Norton antivirus 2004, super ad blocker , Microsoft antispyware beta 1, spyware doctor (paid edition) . MY PROBLEM IS whenever I connect to internet through vsnl connection I get pop up adds from (egroup dialer dialer) & instant access dailer, I have removed it hundred times but again after connecting internet I get popups of game and fun , nothing works please help me to stop it . Whenever I start my computer it says smsse.exe is missing . I have searched my entire computer but did not find any file related to it, please help me removing both of these nuisance.
PLEASE REPLY SOON.
Old 18-03-2005, 03:56 PM   #2 (permalink)
enoonmai's Avatar
Download HijackThis from here
http://www.merijn.org/files/hijackthis.zip
Go here for an excellent Tutorial on using HijackThis (HJT):
http://www.thinkdigit.com/forum/viewtopic.php?t=15729
Run HJT, save the log file and post it back here so we can fix your problem once and for all.
As for the 'smss.exe' problem, click Start>Run and type in regedit. In the Registry Editor that opens, on the left, navigate to :
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Run
and
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run
and see on the right hand side if there is any reference to the smss.exe file. If there is, right click that key alone and delete it. Check the screenshot below for an example, if you get confused.
Do this and you wont see the 'smss.exe' file-not-found error at startup. Also, remember to post your HJT log file here.
Playing FEAR XP/LSW2
enoonmai is offline
Old 18-03-2005, 11:38 PM   #3 (permalink)
swatkat's Avatar
Also, download WebRoot SpySweeper Trial and AdAware and do a FULL system scan usigng it.
After this run HijackThis and post the log file.
http://www.lavasoftusa.com/software/adaware/
http://www.webroot.com/downloads/?WR...59213be4b06d5b
http://swatrant.blogspot.com/
swatkat is offline
Old 19-03-2005, 09:04 AM   #4 (permalink)
Ignorance is BLISS !!
After u r finished with the above solutions, U need 2 install "Spybot Search and Destroy" on ur machine 2 protect it from such threats in the future !
U Can get it at
http://www.download.com/Spybot-Searc...5.html?tag=pop
rajkumar_personal is offline
- by tkin
