Old 18-10-2007, 02:16 PM   #1 (permalink)
Default restart problem
hi
i have hpnx5000 labtop and it runs with xp, sp2.
just few days ago i got a little problem ,
when i logon the system it says"REGISTRY EDITING HAS BEEN DISABLE BY THE ADMINISTRATOR" .and then it restarts .Even i formatted but same problem shows.
help me out
suraj is offline
Old 18-10-2007, 06:47 PM   #2 (permalink)
Jags's Avatar
Default Re: restart problem
can u explain more...??
It seems to me that u have formatted the partition on which xp was installed and re-installed winxp, but the problem remains...rite ??
Jags is offline
Old 18-10-2007, 10:08 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Refer to this thread, point number-->>1
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
you have got some virus.....update your antivirus and than do full system scan in safe mode.Must turn off system restore before scaning.
ravi_9793 is offline
Old 19-10-2007, 09:25 AM   #4 (permalink)
hi ravi
i formated my labtop and again installed winxp.
the problem is ...........it restarts automatically showing one message.
that is "registry editing has been disabled by the administrator."
when i clik "ok" then it suddenly restarts , even it doesnot let me work for a while on that labtop.
suraj is offline
Old 19-10-2007, 03:22 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Boot your system into safe mode and scan for virus's and trojans.
Also update your windows from microsoft website.
Also repair your windows registry using some registry software.Some good and free registry fixer software can be found here:
http://www.techiehome.org/viewtopic.php?t=663
Also do this:
start-->>right click my computer-->>properties-->>advance-->>startup and recovery setting-->>turn off automatic restart
Problem regarding restart Ankit Agrawal Hardware Q&A 2 20-07-2008 02:11 PM
Restart problem... prasad_den Hardware Q&A 4 20-07-2008 01:58 PM
restart problem slyfox Software Q&A 3 07-10-2007 05:34 PM
Help : Pc Restart problem kg_87 Software Q&A 13 25-06-2007 10:21 AM
~~~~~~Restart Problem~~~~~~ freezer QnA (read only) 2 26-10-2005 02:43 PM
- by tkin
