| Forum |
#1 (permalink) |
#2 (permalink) |
could you give us details ? First of all do u have any idea as to what codec has been used in the avi (audio codec). If its AC3 then u need to use the VirtualDub spcifically for AC3. You can use a tool call GSpot to sepecifically find out which audio/video codecs the avi file contains
AMD 64 3500+ Venice DFI Lan Party Ultra-D 2* 512 MB PdP Memory with 2-2-5L timings XFX 7900GT 256 MB Card |
#3 (permalink) |
well i know the ac3 format requires separate coding procedure i have used gspot it says that it has mpeg layer 3 or the mp3 coding for audio and xvid codec for video but still am not able to perfectly cnvert any of them thats why i need some software which directly encodes these files without any separation.
#4 (permalink) |
if u want to write them try drug & drop in nero,
or use TMpeg latest version or if u can`t get ur work done i`ll mail u some link of software(not having them now).
Music is like Sex, The more you get, the more you want. |
#7 (permalink) | |
probs very simple for u but difficult to me may because i am not exactly able to convert this hefty proceudre of divx to vcd's just seems too complicated to me for u it might be pro stuff but man am a amateur at this so try help me out in dummy terms if everything would be as simple as draging and dropping files in nero and then converting them then i wouldn't have had probs but this involves more procedures like converting the audio first and then the video encoding so its difficult for me.now do u get it?so plzz understand. |
#9 (permalink) | |
#10 (permalink) | ||
www.techenclave.com Ecumenical Technology ! |
#11 (permalink) |
Hey Blade thanks for the tip i am starting to use Tmpgenc now just getting stared so will let u know if any prolem with anything particular.can u come on yahoo messenger will try to ask u there if possible.
#12 (permalink) | |||
#13 (permalink) | |
#17 (permalink) |
they are not errors ! actually the problem with the virtual dub is , its in the developemental stage ! so it gets crashed some times
wat you can do is try Video meu go to erros and click on the * Conncel all the erros and start decoding from the next frame * that might help ya a bit or you can use Ulead Video studio , its the best bit kinda a bit slow because of the heavy resources it uses |
#18 (permalink) |
i think ur AVI is already bad...
so it can not detect the right frames to convert to DAT Tmpeg is good. ok? but first aply it with DivFix that fixes errors in DivX Avi's.ok mail me on my site... home page====www.freeinfonet.tk
www.techlads.com Paarth. |
#19 (permalink) |
check this link for all types of conversions ......
http://divx-digest.com/articles/index_english.html#avi2 hope it helps |
#20 (permalink) |
or better still....here u go....a uperb tutorial.
http://www.weethet.nl/english/video_divx2kvcd_subs.php |
| Bookmarks |
| Display Modes | |
