Old 18-03-2005, 11:16 AM   #1 (permalink)
Default 4x AGP to 8X
I got a Radeon 9200 SE its 8x 128MB .
But my MoBo(Krypton M7VIA series) supports max speed of 4x AGP!
Will there be any considerable change upgrading my MBoard to 8X type?
Is there any FLASHy way of foxing my current board to update to 8X without changing the hardware?
If I need to go for a brand new, which to?
NOTE : As always, LIMITED BUDGET !
hell\'s full so I\'m back!
CPU 2GHz +AGP 128MB+ RAM 512 DDR
just for an OS ! heh !
Intruder is offline
Old 18-03-2005, 11:40 AM   #2 (permalink)
dOm1naTOr's Avatar
AGP 8X cards are backward compatible with 4X interface.
Ur new AGP 8X card would automatically scale down to 4X when connected on an 4X pord.The perfomance difference b/w 4X nd 8X is negligible nd it is the GPU that matters nd not the interface(4X or 8X).
But AGP 8Xcard wont run on an AGP 2X on a mobo as it is not backward compatible and the voltages is also different!!!!!
It could even damage the card nd void the warranty!
dOm1naTOr is offline
Old 18-03-2005, 12:54 PM   #3 (permalink)
That was quiet interesting and valuable info !
Thanks a lot
But ....
this is what i need to get in depth to.
Is it correct ? I thought the Bus matters along with the GPU
Intruder is offline
Old 18-03-2005, 03:30 PM   #4 (permalink)
dOm1naTOr's Avatar
The speed of these interfaces(AGP4Xor 8X) is represented in GBps.
But actually there is not yhat much data to work.So these proves to be rubbish.Even a 6800 doesnt need that much speed for interface.Its true....
But we should keep moving on as most of the new technologies are not backward compatible.
These speed usually affects when we have huge amount of Video memory(256 or even 512MB) 256 bit memeory or higher memory in our Gcard and the GPU is much powerful(6800 ultra or X850XT).
Old 22-03-2005, 04:32 PM   #5 (permalink)
rachitboom2's Avatar
Well said again aravind_n20
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Consoles: 3x Xbox 360 Slim 250GB Gamertag: Rachitmayhem
3x PS3 320GB Slim Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
rachitboom2 is offline
- by tkin
