Old 17-10-2007, 12:31 AM   #1 (permalink)
User Name's Avatar
Default uxtheme.dll error
I can't able to install uxtheme.dll it says unsupported OS.
I am using XP with SP2.
Help me.....
User Name is offline
Old 17-10-2007, 01:09 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: uxtheme.dll error
Do you have XP with complete update??
Download from here , and try again to install it.
http://www.osx-e.com/downloads/utilities/patcher.html
ravi_9793 is offline
Old 17-10-2007, 01:11 AM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
for themes moding install windows blind and disable it as a result ur theme files will be patched and windows blind wont hamper ur machine performance
http://beingmanan.com
iMav is offline
Splinter Cell:Double Agent Visual C++ runtime error and ***MUST CHECK*** error zerohourkill Gamerz 17 04-08-2007 02:47 PM
UXTheme MultiPatcher 5.5 Problem c.rajesh Software Q&A 6 15-04-2007 12:57 AM
Error error error....gives me hell of a terror abhilash QnA (read only) 4 06-11-2004 12:41 AM
Problem with uxtheme SpitefulPentium QnA (read only) 6 06-08-2004 11:06 AM
- by tkin
