Old 18-03-2005, 06:34 AM   #1 (permalink)
Laptoping
Sourabh's Avatar
Default Messenger Plus! Extension 3.50.124
Well yess this is for MSN messenger fanatics who have shown great royalty to the the ultra-sucher MSN and have not shifted to Y!m. Personalized comments aside, Messenger Plus! Extension is a program that adds functionalities to the MSN Messenger chat program. Some of the added features are logging, personalized Away Messages, transparency effects, and a feature to minimize all MSN Messenger windows to the system tray.
Find the complete list of changes here
Sourabh is offline
Old 18-03-2005, 11:34 PM   #2 (permalink)
swatkat's Avatar
Messenger Plus! also bundles spywares with it!
http://swatrant.blogspot.com/
swatkat is offline
Old 18-03-2005, 11:39 PM   #3 (permalink)
yes it dones but not discreetly. There is a screen asking you if you wish to install the spyware or not. If you dont also it will function normally. So its ok. YOU DONT HAVE TO INSTALL THE SPYWARE!
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
- by tkin
