lol i forgot to mention that
JUST REMEMBER that this will overwrite all of your ADBLOCK and other settings... so if u have extensions it will overwrite the configs and it will reset them..
the included file readme.txt tells you all about every Prefs and entries that this program adds to your Firefox config file (prefs file), or modifys the existing values and status.
i just tested it, it adds directly to the preferences stored in the 'prefs.
js', some entries according to your chosen type of computer and connection, and some other entries for the 'Performance tweaks common to all configurations' if you also choose this option.
if you know what you're doing, and know a bit on customizing the Firefox you should be able to do all the tweaks that offered by the program easily, either via the about
:config , or create a personal prefs file--user.
js and enter all the prefs into this file.
all changes made through about
:config are written to the prefs.
js file.
prefs set to non-default values in user.
js are also written to prefs.
js.
