Old 16-10-2007, 08:05 PM   #1 (permalink)
photon's Avatar
Cool Can 256 MB be connected with 512 MB
I am having 865GBF motherboard. Which is having 4 RAM slots. Presently i am having 2 256MB DDR 2 400 RAM. Total512 MB . Can i connect another single block 512 MB RAM. Is there will be any compatibility problem due to 256 and 512 difference?
photon is offline
Old 16-10-2007, 08:09 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: Can 256 MB be connected with 512 MB
^^no you can safely connect them.They should preferably have the same frequency.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 16-10-2007, 09:15 PM   #3 (permalink)
Pee into the Wind...
shady_inc's Avatar
For the moment,remove both 256 mb sticks and run your PC on single 512 mb stick.Then,you can sell off those two sticks to get a new same frequency 512 mb RAM.
Life is as complicated as you say it is.
shady_inc is offline
HELP...Extra HDD cant be connected... m-jeri Hardware Q&A 7 17-07-2007 05:15 PM
Is there anyway a tv can be connected to a computer? bavda QnA (read only) 2 27-11-2006 03:55 PM
speakers connected to TV? legolas Audio 3 28-12-2005 06:29 AM
ISP always connected fanatic QnA (read only) 6 21-09-2004 10:04 PM
- by tkin
