Old 12-10-2007, 05:37 PM   #1 (permalink)
Gracias Senor
dreams's Avatar
Default Buying RAM.
Hi Guys,
Finally time as come to upgrade my PC part by part..
First 2 go is for RAM.
My MOB is D845GVAD2.
Memory supported is
Two 184-pin DDR SDRAM DIMM sockets
Support for single-sided or double-sided DIMMs (DDR 333†/266/200)
Support for up to 2 GB†† system memory
The RAM installed in my PC is PTA brand.
Pls suggest a RAM 1GB.
What brand shuld I go for, What should I ask for in the shop, Any specific models?????
Need this urgent.
TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 12-10-2007, 05:52 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Buying RAM.
You can get a Dynet 1gb 400mhz ddr ram stick for 1.7k..
Pathik is offline
Old 12-10-2007, 06:08 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
You need to make sure that the older RAM is DDR 400. Otherwise you may not be able to use both the old and new simultaneously.
The brands you may get are Transcend, Kingston, Dynet. 1GB is enough for you. Here in Bangalore DDR400 1Gb Dynet RAM is available for 1.6k (or mebbe even less).
infra_red_dude is offline
Old 13-10-2007, 03:02 PM   #4 (permalink)
Gracias Senor
dreams's Avatar
I checked my RAM 2day and this is wat pasted in it..
PC2100 DDR SDRAM 32mx64 256MB DDR DIMM
I am not concerned abt the brand.
Does my MOB support 400MHz RAM????
If I go to the shop what how shuld I ask for the RAM.
Will I be asking 4 a SDRAM or DDR or DDR SDRAM with 333Mhz or 400MHz???
I am so confused.
Pls explain in detail guys.
TiA
dreams is offline
Old 14-10-2007, 12:41 PM   #5 (permalink)
brother tell me the names of few good shops in bangalore where i can get cheap and best deals.
viruses is offline
Old 14-10-2007, 12:46 PM   #6 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
go for SP road Bangalore computers and bargain at your best .
the.kaushik is offline
Old 14-10-2007, 12:50 PM   #7 (permalink)
thanks kaushil but i dont like sp road i always get cheated there and they sell old stuff as new.i want names of some branded stores there
viruses is offline
Old 14-10-2007, 01:02 PM   #8 (permalink)
Wire muncher!
Big shops will not sell PC components at such cheap rates. S P Road is where you can get everything at a bargain.
@OP
You can put in DDR400mhz on your system. But if I remember rite, Intel845 supports max 333mhz. So when you throw ina DDR400 RAM, it works at DDR333 speeds. The older RAM you haf is DDR266 (PC2100). So you may not be able to use both simultaneously.
Old 14-10-2007, 01:12 PM   #9 (permalink)
Who told they sell 2nd hand things.. If u want 2nd hand ask them they give u!I am staying in bang for last 5 yrs and assembled more then 12pcs for friends and if some problem comes we have taken those parts directly to the company itself many times and they never had problem with sp road things Also they will give you proper bills which is required when u want any warranty support!
If question is how they make it cheap then the thing is the items are really that cheap but in branded shops they increase the price and shell!
Anyway its all up to u
Old 14-10-2007, 05:28 PM   #10 (permalink)
Gracias Senor
dreams's Avatar
@OP
So I shuld ask 4 a DDR RAM 1Ghz 400MHz Speed isn't it?????
Thnx m8..
Any other suggestions??????
dreams is offline
Old 14-10-2007, 05:39 PM   #11 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
do check latency timming of ur previous RAM also if u plan to use ur EXISTING + NEW ram ....or if u plan to use only new then 1 Gb DDR 400Mhz ram will do....
wizrulz is offline
Old 14-10-2007, 06:54 PM   #12 (permalink)
Wire muncher!
IMHO do not use the older RAM. It may create problems. Jus go ahead and buy 1GB DDR400 RAM.
If you haf any doubts then take your old RAM stick there for identification purpose.
Old 15-10-2007, 05:31 PM   #13 (permalink)
Gracias Senor
dreams's Avatar
Thnx m8.
I luked at deltapage.com and this is wat i saw..
OEM / Brnd. 1.0 GB-DDR-400 400MHz - PC3200 2000 / 2400Rs.
Shal i go 4 this one????
wat is this pc3200???
mine is pc2100!!
dreams is offline
Old 15-10-2007, 05:37 PM   #14 (permalink)
Wire muncher!
PC3200 means DDR 400, PC2100 means DDR266, PC2700 means DDR 333.
1GB DDR400 for 2/2.4k is costly man! Here in Bangalore you get it for 1.7k or so.
Old 15-10-2007, 07:59 PM   #15 (permalink)
Gracias Senor
dreams's Avatar
Tht's wat I am wondering too..let me personally check it out in the stores and wil post the rates.
BTW thnx 4 the suggestions.
But keep it flowing.
dreams is offline
Old 10-11-2007, 01:03 PM   #16 (permalink)
Gracias Senor
dreams's Avatar
Hw do we check the latency timing??
dreams is offline
Old 10-11-2007, 02:03 PM   #17 (permalink)
Wire muncher!
^^^ Use a software like CPU-Z or Everest.
Old 10-11-2007, 02:07 PM   #18 (permalink)
Alive Again...
satyamy's Avatar
Use a Good Ram Like Transcend for Good Performance
Yesterday I bought a 512MB Transcend Ram for 1250/-
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Buying All in One!!! damnthenet Hardware Q&A 20 25-06-2007 04:18 PM
Help in buying UPS Gaurav Hardware Q&A 28 03-02-2007 10:19 PM
RAM buying int86 QnA (read only) 9 22-01-2007 06:11 PM
Buying a New Rig khandu QnA (read only) 41 22-05-2005 08:37 PM
- by Piyush
