Old 17-03-2005, 01:04 PM   #1 (permalink)
rachitboom2's Avatar
Default NTFS to FAT 32 ???
Hi everybody,
Can anybody Pls. tell me any way to convert my NTFS partition to FAT 32 without loosing any DATA of mine ???
Thanks !!!
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Consoles: 3x Xbox 360 Slim 250GB Gamertag: Rachitmayhem
3x PS3 320GB Slim Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
rachitboom2 is offline
Old 17-03-2005, 02:46 PM   #2 (permalink)
The only option is to backup your data to a different partition or drive and reformat with Fat32. If the partition contains windows then you need to reinstall windows.
sailendra is offline
Old 17-03-2005, 05:24 PM   #3 (permalink)
GameAddict's Avatar
Default Search a bit....
May be this will help:
http://faq.arstechnica.com/link.php?i=1820
GameAddict is offline
Old 18-03-2005, 12:39 PM   #4 (permalink)
Is there any other way ???
Old 21-03-2005, 06:25 AM   #5 (permalink)
Fresh Stock Since 2005
Partition Magic may help. Not sure Though................
khattam_ is offline
Old 21-03-2005, 10:33 AM   #6 (permalink)
No bro. but Partition Magic didnt work for me the first and the only last time I tried to do something like that !!!
Old 21-03-2005, 08:30 PM   #7 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Hey guys out here i want to ERASE (FORMAT my hard disk) every bit of data from my hard disk and install a fresh copy of WIN-XP PROFESSIONAL on my c-drive
I am having 3 partitions---->
C (14.11 GB)
D (11.11 GB)
E (11.11 GB)
and i want to use only one operating system (i.e WIN-XP PROF. edition)
So any suggestions as to how can i erase (format) every drive??
Plz help needed......
ashu888ashu888 is offline
Old 21-03-2005, 09:41 PM   #8 (permalink)
C (14.11 GB)
D (11.11 GB)
E (11.11 GB)
u need to just format the partitions or want to remove the partitions too???
if u just wanna to erase everything WITHOUT removing partitions just simply right click on d: nd e: nd select format frm there... as far as C: is concerned format it frm the setup of winXP...
incase u wanna play around with partitions use partition magic...
grinning_devil is offline
Old 21-03-2005, 09:44 PM   #9 (permalink)
Hey my question still remains => Is there any other way ???
Old 21-03-2005, 10:05 PM   #10 (permalink)
i think i replied to "ashu888ashu888", nd quoted his post....
nd rachit u cant convert NTFS to FAT WITHOUT loosing data.....either convert it or loose the DATA...why not copy the data to a diff partition first????
Old 22-03-2005, 05:51 AM   #11 (permalink)
Yeah the evaluation version doesn't work..........................
khattam_ is offline
Old 22-03-2005, 09:47 AM   #12 (permalink)
Hey dude just who the hell said that it was a evaluation version, it was a full version,
it gave errors while it was doing some conversion and formating, and the system got hanged.
Old 22-03-2005, 10:56 AM   #13 (permalink)
Hey@devil i want to erase everything WITHOUT removing the partitions and also Dude i tried to RIGHT CLIK the particular drives and format it but it started giving me problems yaar so i want to FORMAT the HARD DISK using a bootable floopy wich i already have but i dont know the DOS commands to do the formatting so plz if u or any of u guys here can give me the complete list/code of formatting in DOS for all of my 3 PARTITIONS (c,d,e)then i will be gr8ful to u.I am having FAT32 on all 3 of my partitions and want to install a fresh copy of WIN-XP PROF. EDITION on C:drive.
thanx, cheers n peace.... :roll: :roll:
Old 22-03-2005, 11:24 AM   #14 (permalink)
@ashu888ashu888 : what was the error message u recvd when u tried to format it using right click??? have u tried it in safe mode???
still if u need to format it using bootable DOS diskette,the command will be
> format d:
nd
> format e:
thats it ...
Old 22-03-2005, 11:30 AM   #15 (permalink)
do u think sumone will try to help u with this way of talking???? sheeeeeesh such creatures ... shud be banned
nd how many times will u keep on asking "is there any other way??"
there IS NO WAY
Old 22-03-2005, 11:46 AM   #16 (permalink)
> format d:
nd
> format e:
thats it ...
So u mean after the C drive is formatted then i shud go in to format the d and then the e drive?? one by one??
Hey ""devil"" is this step right?? the one wich i am writing down !!
Insert your boot disk in the floppy drive and start the computer. Once the system has completed booting and an A: prompt appears we are ready to start.
Type: format C: /s [press Enter]
This statement tells the system to format your "C" drive and when it is finished to copy the system files to the drive, (the /s switch for 'System'). You can format a different drive this way by using a different drive letter.
but tell me after i hv formatted all my 3 drives then how will i install a fresh copy of WIN-XP on my C frive?? after the formatting is done shud i insert the windows xp professional CD into the cd rom and select the boot preference as the CD ROM and install the OS?? plz suggest?? Dude.......
Old 22-03-2005, 11:59 AM   #17 (permalink)
@ashu888ashu888....hey check out this link ...
http://support.microsoft.com/?kbid=313348
Old 22-03-2005, 12:11 PM   #18 (permalink)
thank devil for giving me that link i will surely try that and tell u in evening or 2moro dude.....
cheers n peace.....
ASHU....
Old 22-03-2005, 03:17 PM   #19 (permalink)
grinnig_devil wrote:
@ashu888ashu888....hey check out this link ... http://support.microsoft.com/?kbid=313348
Hey Devil the link wich u gave me was related to WIN XP installation using the DISK MANAGEMENT WIZARD but thanx for ur help yaar . But wat my question was that HOW TO FORMAT USING THE BOOTABLE WIN 98 FLOOPY that I have.and Now since i hv formatted all my 3 drives (c,d,e) now after formatting and restarting,I get a c: prompt (in black background ,much more like a DOS OS ) so shud i Type in the command "setup" and clik enter and insert my WIN XP CD into my CD ROM DRIVE?? (its F:\ drive for my CD ROM)
Will this querry is NOW HOW TO INSTALL WIN XP PROFESSIONAL EDITION on my newly formatted C: drive.
plz help guys..............
thanx cheers n peace...
Old 22-03-2005, 03:18 PM   #20 (permalink)
Old 22-03-2005, 03:19 PM   #21 (permalink)
Old 22-03-2005, 10:14 PM   #22 (permalink)
Hey Mr,
You just need a bootable WinXP CD and thats all you need, you don't need a bootable floppy. Looks like you have never done the XP installation thing...................
Just boot into the computer with a bootable Cd and choose to install Windows by reading the onscreen instructions.........
Once it will ask that if you want to format the disk (with Ntfs Or FAT32 partition, quick or full format and such options will be available) or leave the disk as it is. Choose to quick format the C: only. Other drives acn be formatted after you install windows..........
Thats all man..........
khattam_ is offline
Old 22-03-2005, 10:46 PM   #23 (permalink)
enoonmai's Avatar
@ashu888ashu888: First of all, do not post 4 times in a row. Use the "Edit" button to change/add information to your post. Also, do not use the bold font so much. We can read normal font.
As for the installation of Windows XP, here's what you need to do. Like khattam said, you can just insert the bootable Windows XP setup disc into your top most CD/DVD drive, and while the computer starts, at the BIOS test, press F8 to enter the boot selection screen. Select CDROM and press Enter. You will be given a "Press any key to boot from CD" message. Do so and follow the instructions on screen to setup Windows.
In case you dont have a bootable CD, boot using any other bootable medium, say a floppy. Make sure you select the "Boot computer with CDROM support" option. Once at the command prompt, enter the drive letter of your CDROM say, F: and then press enter. Once in the CD directory, enter these commands:
cd i386
winnt.exe
and then follow the steps to install Windows XP on your computer.
Playing FEAR XP/LSW2
enoonmai is offline
Old 24-03-2005, 02:33 PM   #24 (permalink)
Hey ashu888ashu888 just what the hell are you doing yar I mean posting sooooooo many times !!!
You can simply edit your previous posts and add the new thing there !!!
Old 27-03-2005, 03:53 PM   #25 (permalink)
yeah bootable xp will do it, but if u made that cd using a floppy disk to make it bootable then the conventional thing (i.e. going to cd drive n then typing setup.exe) is not gonna work, in this case go to i386 folder(cd i386) then type winnt.xyz (i forgot the extension, may be it is exe but check by typing dir winnt*) at command prompt, then setup will start.
Ashootosh is offline
Old 27-03-2005, 11:13 PM   #26 (permalink)
Partition Magic can help
http://www.powerquest.com/partitionmagic/features.html
Latest Full version will do. But at your own risk...........
khattam_ is offline
Old 29-03-2005, 03:30 PM   #27 (permalink)
partition magic can only help when u can enter the windows.......... not at this time, but yes i agree he should use partition magic at first. I have bootable partiton magic, search if u can find its iso image on net.
Old 29-03-2005, 09:35 PM   #28 (permalink)
Oh no illegal things here............
khattam_ is offline
Old 30-03-2005, 10:49 AM   #29 (permalink)
I dont think so bootable PM is illegal or pirated(or is it??), i think it has been made by an Indian programmer without using any details of PM, it just got the looks of PM................. but not to sure
- by Piyush
