Old 12-10-2007, 01:03 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default nLite ! ! !
its been talked all on this forum ...... so a small thread 4 newbies or ppl who rn`t aware of this softy ...... if already posted .... delete this thread ....
Nlite :
nLite is a GUI (Graphical User Interface) that lets you do a permanent removal of Windows components that you've decided not to retain on your PC. After the removal, you get an option to make a bootable image, which won't contain the components that you removed prior to making the image. You can test this image in virtual machines or burn it onto a CD to do a fresh install.
nLite Features:
* Service Pack Integration
* Component removal
* Unattended setup
* Driver integration
* Hotfixes integration
* Tweaks
* Patches
* Bootable ISO creation
OS : windows version Windows 2000/XP
Hpage : http://www.nliteos.com/
Download : http://www.nliteos.com/download.html
... W H O T ...
ax3 is offline
Old 12-10-2007, 01:21 PM   #2 (permalink)
99.9% Idle
axxo's Avatar
Default Re: nLite ! ! !
& vlite required to remove the bloats in vista
axxo is offline
Old 21-10-2007, 10:02 AM   #3 (permalink)
Back in Power
almighty's Avatar
very old one
i ve posted it 3-4 months back
customize vista and xp as per ur requirment
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 21-10-2007, 12:07 PM   #4 (permalink)
sourav's Avatar
does anyone know
how to make a bootable dvd with xp, vista and windows 2003 and with some extra installation files like office 2007
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 21-10-2007, 12:16 PM   #5 (permalink)
Back in Power
almighty's Avatar
ya i know
almighty is offline
Old 21-10-2007, 12:31 PM   #6 (permalink)
sourav's Avatar
wah
do i need to say
please lend your knowledge about it to me.
anyway how to do it
sourav is offline
Old 21-10-2007, 12:48 PM   #7 (permalink)
The Transcendental
nlite & vlite are soooo buggy.
its better to do everything manually so you know the exact consequences of your actions. And better make a reg and unreg file of every tweak you do. Its better that way.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 21-10-2007, 07:05 PM   #8 (permalink)
Back in Power
almighty's Avatar
did u use nlite and vlite???
I used both of them and i can say they are the best slipstreaming s.w
ya they have some bugs but that doesnt mean they are buggy
Only IE7 intergration gives bug of unrecognized version of driver
and in timezoe(if india selected) it get back to 1 hr back...
thats it and its well knowned by any nlite user...
nuhi released new nlite with these fixes 1 or 2 week before
@saurav
check these links
if need some help ask me anytime
realy u like to play with....
http://www.msfn.org/board/nLite_f89.html
Raid/Sata slipstream in xp (No F6 needed while installation)
almighty is offline
Old 22-10-2007, 10:06 AM   #9 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Buddy..
wht r the bugs present in its latest version.....
||uLtiMaTE WinNER||
Ron is offline
Old 22-10-2007, 10:13 AM   #10 (permalink)
Back in Power
almighty's Avatar
Not tested yet latest version
almighty is offline
Old 23-10-2007, 06:00 PM   #11 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Hey buddy.......
I hv never used Nlite before..
Wht r the thing I should do before using this software...............
Suppose:
If I hv done fresh installation of windows xp. ....and
i hv installed few softwares..and ..Ms Office Pack...
Now i what is the next step
Thnks iN Advance
||uLtiMaTE WinNER||
Ron is offline
Old 23-10-2007, 06:26 PM   #12 (permalink)
Back in Power
almighty's Avatar
@ ron
Nlite is used to intergrate or remove s.w,hotfixes,drivers.
Its better knows as Slipstreaming
With Nlite u can make(ammend) xp as per ur requirment...
Originally Posted by Ron
Suppose:
Thnks iN Advance
Nlite is just a slipstreming s/w which only need .net framewok to be installed on ur pc to run Nlie
u can use it for making unattended xp with all drivers and hotfixes...
so u dont need any driver/hotfixes/s.w to install after xp installation...
almighty is offline
Old 24-10-2007, 12:46 PM   #13 (permalink)
ax3
ax3's Avatar
@Ron ....... u just made nlite useless 4 u ..... anyways use it next time .....
@almighty ...... has all ans .........
... W H O T ...
ax3 is offline
Old 24-10-2007, 01:57 PM   #14 (permalink)
anand1's Avatar
Yesh till yesterday i was searching the net for how to include my Driver into the windows installation CD but i was not successful . I even gone through the thread
Do It Yourself-Tech-Savvy way to April-07 Take A Crack
This tell us how to manually configure the Bootable Xp CD but also i was not able to do.
After reading i downloaded the nLite and its really working. I have made the ISO image of the CD and looking forward to burn it on CD which will be the special for my PC. Hurray !!!!!!
Technology On The Fly
anand1 is offline
Old 24-10-2007, 04:20 PM   #15 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Thnks Guys
Hey..
According to the Guide.
We hv to copy the windows source files into a folder...
Now wht is this?Is is the Windows Installation CD?
Thnks in Advance
||uLtiMaTE WinNER||
Ron is offline
Old 24-10-2007, 04:24 PM   #16 (permalink)
Back in Power
almighty's Avatar
yup
y need bascialy i386 folder to slipstream(but recommended to all files for n00b)
make a new folder and copy all files from ur xp cd...
its the first step of nlite
u need not to copy anything manualy
just make a new folder and rename it xpcd
thats it
anything else?
almighty is offline
Problem with NLite janitha Software Q&A 2 16-07-2007 04:56 PM
nLite 1.3 Final alsiladka Technology News 9 06-03-2007 10:51 AM
How 2 use nLite???????????? Naveed Software Q&A 1 26-01-2007 03:08 AM
- by Piyush
