12-10-2007, 11:05 AM
TATA Indicom Plug 2 Surf
I'm sure you already know about the Tata Indicom Plug 2 Surf -- with all these ads flashing in our face during the entire World Cup series. One ad goes like this: Bollywood celebrity Kajol walks in on an aspiring model and a couple of her friends. She inserts the Plug 2 Surf (a USB device) into the laptop and presto! They are connected to the Internet. Let's investigate this little device and see if it really provides for a happy ending (read a good solution for your net connection).
USB modem
Driver CD & manual
Options
Plug 2 Surf is a Code Division Multiple Access (CDMA) device, and it comes in 2 options. One is a standard Plug 2 Surf and the other is Plug 2 Surf Whiz. The main difference between the 2 is that while the first supports only Windows OS (including Vista), the latter supports several OSes (including Windows OS) except for Vista.
Setup
The Plug 2 Surf is an easy install. Just insert the mini-disc into your optical drive and run the setup. A restart after the install completes, and then you attach the USB modem and you're good to go. The "Plug 2 Surf" is possibly inspired from "Plug-n-Play" -- though it doesn't really work as one: you need to have the mini-disc present.
Tariff Plan
While considering the purchase of this device, it's mandatory to pick a tariff plan as well -- else the device is useless. There are about half a dozen tariffs to choose from, but all of them are time- or data-based -- quite an expensive deal actually. Here are the plans available:-
The phone plan is standard, and pricing is pretty average, considering that you'd be using the device more for Internet access.
Features
The Plug 2 Surf has a list of features that make it more than just an Internet device. You can also use it to make and receive calls and send and receive SMSes as well. But it doesn't happen with the net connected, as it's just a modem and can do just 1 thing at a time -- either Internet or call or SMS.
The device uses a SIM (Subscriber Identity Module), so it's going to be easy to use your Tata Indicom SIM that you use in your phone. Just call the customer service and activate the scheme of your choice. Thus, you save the cost of a separate SIM
The software that is bundled along with the device syncs the SIM with the PC. It lets you read and send SMSes as well. You can also add and edit contacts and make calls through the address book option. The SIM can hold 1,000 SMSes and phonebook entries each
Internet
The Internet connection of the Tata Indicom Plug 2 Surf is decent. It takes about 5 seconds to establish connection after you hit the connect button on the dialer. Surfing in the worst connected areas, I could still surf one site at a time peacefully. That would be about 4-5KBps. Move to a good network range, and Web pages open without much waiting. I conducted some Internet speed tests, and here are the results. We took one from McAfee "SpeedoMeter" and the other from CNet "Bandwidth Meter". In both cases the speed test results were around 15KBps. Even while conducting real-time download tests, the results were more or less the same while downloading from either http or P2P networks. The speed mentioned is 153Kbps, which translates to 19KBps
Experience
I was expecting a plug-n-play thing. But the Plug 2 Surf didn't turn out that way. You need to install drivers, which come on a mini-CD, before you can connect. The mini disc could easily have been eliminated from the equation by just adding some memory within the device. There would be no hassles of running around with a CD, and that would have made it a complete Plug-n-Play device, just as shown in the advertisement. The memory provided could have been a 1GB or so just to make it a combination of Plug-n-Play Internet and a pen drive. But just like there are 2 sides to a coin, there could be issues with having memory installed. It could heat up the device more than it presently does. (CDMA network devices tend to heat up very easily.) So, adding memory could lead to an eventual malfunction and the device going faulty.
Conclusion
The Tata Indicom Plug 2 Surf connects through the most standard interface USB. And it sells for Rs.2,600 with a SIM. Add to that your tariff plan charges, which will be time- or data-based. The deal here is that you wish to have a net connection that you can take with you and use it with both you laptop as well as desktop PC. Finally, its build: it has a nice, black matt plastic.
Source:
http://www.techtree.com/India/Review...817-538-1.html
We must accept finite dissapointment. But we must never loose infinite hope.
15-10-2007, 11:39 AM
Cool as a CUCUMBAR ! ! !
Re: TATA Indicom Plug 2 Surf
thanx 4 this review .......... will get it 4 my laptop ........
... W H O T ...
15-10-2007, 11:46 AM
Rubik's Uncle!!
Nice review.
15-10-2007, 01:23 PM
=--=l33t=--=
15kbps? thats more than pathetic...
15-10-2007, 01:28 PM
Commander in Chief
Lol yeah I was wondering the same thing, why are you saying 15kbps is good? Its lower than those old phreaking days modem rates! But then, speed tests aren't exactly accurate in the first place. You just started off a K Bps vs K bps war again
Harsh J
www.harshj.com
15-10-2007, 01:59 PM
Yes. 15KBps is what one gets using Data cards. Expensive in long run.
For 1GB data transfer---> Rs.700 / month
Instead get a EDGE enabled mobile and subscribe to GPRS. The speed is the same. But lot cheaper. Rs350/month unlimited data transfer!
Kiran Kumar R
15-10-2007, 02:41 PM
Mclaren F1 Long tail
This is not his orignal review he has just copy pasted it from techtree,having personally run the above on a laptop running vista business it is nothing but pathetic,high speed internet is all crap and it only is a little faster than dial up and clearly here the famous phrase upto 153 Kbps has been misued to the full extent and real speeds are in the order of around 64Kbps or 8KBps even in open areas.IMHO it is still not a good product from tata and we still are being charged exhobirant prices for overtly poor speeds.The above device is useful only where your laptop does not have a pcmcia slot otherwise a data card is still better you do not have to plug and unplug it although it may not give you any increase in speed.As a conclusion the wireless solutions from reliance and tata are still providing poor speeds for the prices being charged and as kiran said one is better off with a mobile for using internet on your laptop.
Computers are like air conditioners. They work fine until you start opening windows.
15-10-2007, 03:17 PM
Nice Review, thanks
No, actually its 15 KBps.
15-10-2007, 03:58 PM
Commander in Chief
He was referring to your speed test picture, the SpeedOMeter.
Harsh J
www.harshj.com
15-10-2007, 04:00 PM
=--=l33t=--=
Yup. that is kbps... not KBps
15-10-2007, 07:24 PM
!FREEWARES!
TATA plug 2 surf is pathetic.. Plus u wil hav to go thru hassles of wrong billing.
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
15-10-2007, 08:11 PM
Fast 'N' Furious
^^^^ That's shocking - I am also facing probs with reliance connction
anyway thanks sourav for this review
15-10-2007, 08:18 PM
TechFreakiez.com
thx for da review...i was about 2 buy dat connection....but i'll not buy it....lolz...its realy a piece of shi*....now can ne one suggest me an EDGE enabled cheap cell phone and details on AIRTEL GPRS connection thru which i can connect 2 internet...
Personal Log | Star date 05.04.2009: TDF Meet Kanpur was Awesome :D
www.TechFreakiez.com
15-10-2007, 08:46 PM
thanx for this, i did copy from techtree, you can see the source.
but, i am using this, it is not so bad, but you should not think it of as alternate to your broadband connection. if u compare this to broadband, this would be wrong.
i agree tariff plan is not correct and in comparison of spped and tariff, it is lot better than reliance.
If you are taking laptop, then please think off BSNL datacard. It is a lot better option in comparison to this. But i cannot to that as it is PCMCIA based and no desktop support pcmcia interface and as i have sometimes connect it to laptop and sometimes to pc.
N.B.: I made this so that everybody can know about this.
16-10-2007, 09:29 AM
still a long way to go, i think wi max/3g will be better. also there is a problem with conectivty. you keep losing conectivity every time u try to d/l some big file.
16-10-2007, 09:38 AM
Bond, Desi Bond!
Dude. Better stay away from this. There is not unlimited data option.
My colleague got this and at the end of the month, got a bill of Rs.1500 saying that he exceeded 1gig limit. All that he used internet is for chatting, checking mails. Better go for service that gives unlimited data
16-10-2007, 10:08 AM
Thanks for the review.....looking for this for a long time,Thanks a lot.
16-10-2007, 12:54 PM
oops ...... i will have 2 think again .......
am looking 2 surf from my laptop ...... as my landline wires r 2 BAD & have an old exchange ....... so no chance of calling them .......
... W H O T ...
16-10-2007, 09:35 PM
#19 (permalink)
my connection doesnot drop at all at any time
16-10-2007, 10:37 PM
#20 (permalink)
Back in Power
Airtel MO rocks ....in 249 buck UL with 15-16 kBps
See the difference
My net speed with nokia 3230 (Non EDGE)
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
18-10-2007, 09:19 PM
#21 (permalink)
TechFreakiez.com
hey almighty can u plz tell me more about ur net connection with airtel...details plz...rentals and all dat plzz..
18-10-2007, 09:37 PM
#22 (permalink)
Back in Power
I am using Airtel Mobile Office on monthly rental i.e. rs. 249/month, from Nokia 3230 via data cable....I tweaked my registry to get some more speed, but without any tweak too i get 10-12 kBps...sometimes it goes down to 5-6 kBps but once in a week for 10-12 hrs only....
I suggest everyone to go for mobile office, coz it gives Unlimited usages,with better speed atleast better than these reliance,tata and bsnl cards....
(Bihar/Jharkhand Airtel mobile office dont have EDGE support,
so dere is no point,I am getting that much speed by GPRS only...)
Boost ur net speed :)
EDIT:- But Airtel has the WORST customer service,The f***ing executives alwayz tell u, SYSTEM IS UNDER UPGRADATION, kindly call back after some time
LOL
19-10-2007, 01:22 AM
#23 (permalink)
Beware of the innocent
for those who are unable to get broadband due to lack of last mile connectivity, I guess this is the only choice. Can't ask an office user to get his mobile for edge. And can't give him an office mobile for internet either. By the way, just checking, 5 kbps in poor connectivity areas is better than dialup right?
The silliest issue I face at our office at badshahpur is that when the power goes out (It is out most of the daylight hours) most of the local mobile towers also go off the air. So much for the communication revolution in Gurgaon.
Life is too short. Have fun.
24-10-2007, 10:34 AM
#24 (permalink)
Tribal Boy
I use the Tata plug 2 Surf extensively. Like 12-14 hrs a day. As others mentioned, it is good for people who do not have any other options, like no broadband etc (in short, like me !)
Only problem I found, it get heated up after using for 3-4 hrs continiously, the speed goes down when its heated up. Disconnecting it and re-connecting after 2-3 minutes makes it ok though.
And yes, it is not pure plug and play, can't use it every where, we need to install the necessary drivers and softwares. May be they have a special version for Kajol to use it in any Laptop - WOW
Regarding tariff, only Reliance data card / BSNL data card gives unlimited usage option. Tata has a 5 GB cap
@almighty
Consider yourself very lucky if you are getting 15-16Kbps using the Airtel GPRS alone. Most do not get that much even after doing all tweaks etc. So far I heard only EDGE users get that speed.
24-10-2007, 05:30 PM
#25 (permalink)
^^Same problem with me. The modem worked exceptionally well in the first month after connection . But after first month, the speed slowed down. The connection drops if connected for too long(more than an hour)
27-10-2007, 03:43 PM
#26 (permalink)
Hey dude, Plug 2 Surf Whiz does support Vista now. You've got to download the drivers from the Tata Indicom website. In the ad how does Kajol plug in her Plug 2 Surf Whiz in someone else's computer without the drivers. Cuckoo land is indeed, advertising........
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Tata Indicom (help)
Chirag |
QnA (read only) |
7 |
19-09-2005 12:17 PM |
Tata Indicom Internet
premsharma |
Mobiles and Tablets |
6 |
12-09-2005 01:02 PM |
