Old 19-08-2004, 12:20 AM   #1 (permalink)
Default CMOS CHECKSUM ERROR
I have been using my system for last 4 years. It is a Celeron 633 on 810 motherboard with 192MB RAM. Last one week i noticed my computer clock going slow, after two or three days I got the message "CMOS Checksum Error Defaults Loaded" Press any key to continue.
I changed the M/B Battery, but the problem persisted, then i tried to to clear the CMOS memory by shorting the Pins, that did not help either.
I now seek HELP.
Incidentally i visited the web and found that my processor might have been damaged. Is it true?
tirthasanyal is offline
Old 19-08-2004, 02:56 AM   #2 (permalink)
mariner's Avatar
i screwed my celeron 800 the same way a coupla years back . its wise to call up ur friendly neighbourhood spiderman !! ooops technician !!
mariner is offline
Old 19-08-2004, 11:04 AM   #3 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
I feel sorry to inform u that your motherboard battery has passed away. Kindly relieve it of this material world through a dump-inthe-dustbin funeral and begin a new life by getting a new motherboard bettery. My condolences are with u.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 19-08-2004, 01:23 PM   #4 (permalink)
Jai Suresh
lywyre's Avatar
Check that you enter into the BIOS Setup and save the settings.
I hope this works.
lywyre is offline
Old 19-08-2004, 07:12 PM   #5 (permalink)
After changing the setting and with a new battery, restart the machine and check if the setting are saved. If yes and still your computer's clock is running wild then it means your motherboard's Crystal has gone nuts !!!.
Take it to the hardware technician.
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 20-08-2004, 12:19 AM   #6 (permalink)
i said i had changed M/B battery, also tried to clear the CMOS and then by entering BIOS changed the settings. but those actions did not helped.
Old 21-08-2004, 02:00 AM   #7 (permalink)
busyanuj's Avatar
then take the motherboard to the technician.
busyanuj is offline
Old 21-08-2004, 06:50 PM   #8 (permalink)
The Photoshop Guy
cooljeba's Avatar
yep m8 i think ur mother board gonna expire soon if u don't take it to the technician!!!
..:: peace ::..
Jeba
cooljeba is offline
- by Piyush
