Old 11-10-2007, 07:01 PM   #1 (permalink)
Default Batch scripting
Hello,
I need to do the following thing.
1) connect via telnet to a computer
2) enter password
3) execute few commands
I made a batch file to execut the commands. It works properly when i copy and paste them to telnet sessions.
Now I want to connect to the comupter via batch file. So, my batch file content was like this:-
@echooff
telnet xyz.com
set of commands
set of commands
When i execute the file the, I get connected to the computer but it prompts for password. How can I make it read the password from the file rather than prompting. Also, I want the set of command to be executed inside the telnet session.
How can it be done.
Please help
rishav is offline
Old 11-10-2007, 08:31 PM   #2 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Default Re: Batch scripting
There is a Separate Telnet Scripting Tool! It allows you to automatically login to a Telnet Server, execute commands and then Exit.
Some people use it with Task Scheduler to automatically reboot their Routers
http://rapidshare.com/files/61825245/TST10.zip.html
Get that tool and just run it for the Readme.
(That tool was taken from Here)
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 11-10-2007, 08:45 PM   #3 (permalink)
can u give me more info so that i can google it and dl. rapidshare not working for me right now.
rishav is offline
Old 11-10-2007, 08:54 PM   #4 (permalink)
God of Mistakes...
Garbage's Avatar
can u use parameters for password ??
I think we can pass 9 parameters for BATCH file...
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 11-10-2007, 09:00 PM   #5 (permalink)
[xubz]'s Avatar
Just google for 'Telnet Scripting Tool
[xubz] is offline
Old 11-10-2007, 09:06 PM   #6 (permalink)
thanks
rishav is offline
Old 11-10-2007, 09:06 PM   #7 (permalink)
God of Mistakes...
Garbage's Avatar
Here is the site http://www.winsite.com/bin/Info?500000000873
and Download Now !!!
Garbage is offline
[Scripting] PHP Troubles NikhilVerma QnA (read only) 4 29-08-2005 07:44 AM
HELP shell scripting!! mediator Open Source 3 13-08-2005 12:33 AM
Scripting QuickLaunch rohan Tutorials 2 20-05-2005 12:05 AM
Windows Scripting kinshuksunil Software Q&A 6 05-01-2005 12:01 AM
- by Piyush
